need help asap brakes
Old Dec 1, 2007 | 06:58 PM
03redzo6's Avatar
03redzo6
Default need help asap brakes
I知 trying to install my rotors and pads but I知 having trouble taking the caliper bracket off, I知 assuming you turn the 21mm bolts counter clockwise or is it backwards. Thanks, Albert.
Old Dec 1, 2007 | 07:15 PM
stormrider's Avatar
stormrider
The is a flat spot on the bolt under the rubber boot that you place a wrench on to keep the bolt from just spinning. PM me your email address and I will send you instructions w/pics that will walk you through the entire process.
Old Dec 1, 2007 | 07:45 PM
99mallett's Avatar
99mallett
From: The line waiting to see Santa Claus stretched all the way back to Terre Haute, and I was at the end, Indiana
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18
Last ones I took off needed an impact wrench to break the red Locktite loose. A little heat may help too.
JPM@AutoBuffs's Avatar
0JPM@AutoBuffs
Former Vendor
From: The AutoBuffs Army is unmatched in the Custom world! www.autobuffs.net
S. Jersey Events Coordinator
Cruise-In IX Veteran
Old Dec 1, 2007 | 08:19 PM
RonJ's Avatar
RonJ
A good 6 point socket, a long bar or a short bar with a pipe over it. Be sure to keep the socket sitting squarely on the bolt head!! It'll come!!
RonJ ...
Old Dec 1, 2007 | 08:22 PM
Bob CTS's Avatar
Bob CTS
stormrider, OP is talking about the bracket bolts, I had to use an impact as well those guys were on there. It can be tricky to get a breaker bar on some of them but if you have access the impact will make it so simple.
Old Dec 1, 2007 | 08:35 PM
stormrider's Avatar
stormrider
Your right, my bad.....impact wrench or braker bar is the way to go
Old Dec 1, 2007 | 09:31 PM
Jason's Avatar
Jason
CI 4-5-6-7 Veteran
Big hammer
Old Dec 1, 2007 | 10:46 PM
03redzo6's Avatar
03redzo6
Thanks guys for all your help. We had to us a blow torch and a rubber mallet to take those suckers off, because for some reason my impact gun could not take them off.
Old Dec 1, 2007 | 10:49 PM
4GTABODT's Avatar
4GTABODT
From: Mississauga, Ontario Corvettes were built to be driven...not trailered
St Jude Donor '07-'08-'09
Sounds like someone before you used Red Locktite instead of blue. Good to hear you got them off...i usually have to use Breaker bar and some convincing from a rubber mallet too
To need help asap brakes
