[Z06] Confused
Old Dec 2, 2007 | 07:24 PM
cobrakraiger's Avatar
cobrakraiger
Default Confused
Okay I'm new to the forums and I just picked my Z up yesterday. I want to get an intake for it, and I have been searching and searching only to confuse myself. I see the hurricane looks good but it seems like a big pita to install, but it seems to be one of the only ones that is a "real" CAI. It looks like the honker comes highly recommended but is on backorder. My buddy has the K&N and he seems to like it and his g/f has the Blackwing (I think thats what it is called). What are the main differences between all of these? It looks like where the air is coming from? Also what would you guys get and where should I order it from to get a good price? Like I said I'm sure this subject has been beat to death and I'm sorry to bring it up but I want to make sure I get a quality piece that will make power and not throw check engine lights.
Old Dec 2, 2007 | 07:29 PM
TEXHAWK0's Avatar
TEXHAWK0
I would just leave the stock intake on it.
You are not going to see any noticeable increase in power unless you make changes to improve the flow though the engine and exhaust system. Some of the aftermarket intakes initially have lower restriction, but they also allow more dirt to pass through and increase pressure drop faster than a stock filter.
http://home.stny.rr.com/jbplock/ISO5011/SPICER.htm
Old Dec 2, 2007 | 07:34 PM
NightmareZ06's Avatar
NightmareZ06
take a look at the vararam intake. Dyno proven numbers and you ca see how functional it is.
Old Dec 2, 2007 | 07:47 PM
FASTBLACKLS6's Avatar
FASTBLACKLS6
St. Jude Donor '10
Old Dec 2, 2007 | 07:51 PM
bullitt4110's Avatar
bullitt4110
I like the Callaway "Honker" a lot. It is proven to be one of the best.
Old Dec 2, 2007 | 08:36 PM
Zosixin's Avatar
Zosixin
I have the Blackwing. It seemed to add a little hp when my car was stock. I got it used for $100. I would not buy one new. They are always some one selling one in the parts section. They are all about the same. The vararam maybe makes a few hp more.
Old Dec 2, 2007 | 09:18 PM
irokru's Avatar
irokru
I'd just enjoy it stock for awhile. Ya know it's got an incredible fun factor just as is.
Old Dec 2, 2007 | 09:57 PM
Solofast's Avatar
Solofast
Other than some additional induction noise it the benefit vs keeping a fresh clean paper element in there is minimal. Put in a new element every year and just forget it...
Old Dec 2, 2007 | 10:08 PM
C5Z's Avatar
C5Z
There have been perceptable and proven reductions in 1/4mile ETs and HP increases with aftermarket intake systems and Vararam is one of the good ones. Lucky for you they are on sale right now from a supporting vendor for a great price.
http://forums.corvetteforum.com/show....php?t=1877166
Old Dec 2, 2007 | 10:43 PM
Gray Ghost GS's Avatar
Gray Ghost GS
"AlohaC5" Senior Member
I use to use the Blackwing, but went to the Callaway "Honker" and found it to provide superior CAI performance.
Old Dec 2, 2007 | 10:50 PM
cobrakraiger
Can someone post some pics of the Honker or what setup they are currently running. Also where is the best place to get a honker? What does everyone think about the K&N setup?
Old Dec 2, 2007 | 10:54 PM
PeteZ06's Avatar
PeteZ06
St. Jude Donor '07-'08-'09-'10-'11
Halltech is a popular choice as well.
Old Dec 2, 2007 | 10:57 PM
cobrakraiger
Does the Halltech have a model name or is it just the Halltech?
Old Dec 2, 2007 | 10:59 PM
Gray Ghost GS
I purchased mine at "Corvettes of Houston", but many forum vendors sell them. Check on the link for a picture and price (Free Shipping).
Old Dec 2, 2007 | 11:14 PM
cobrakraiger
Well after looking at the vereram I think it is out. I just cant trust those little screens to keep all the dirt and grime away from my motor.
Old Dec 3, 2007 | 11:21 AM
hotwheels57's Avatar
hotwheels57
I had a complete BLACKWING set up with the "ice box" cover. I got intermittent codes, mostly because of our 5,200 ft altitude, maybe because the '04 Z16 is supposed to be a little leaner from the factory. I didn't want to drive 300+ miles round trip for a $500 tune.
I decided to return to a modified oem Z06 intake. This took me about one hour with a DREMEL. The aluminum screen came from TARGET...they have inexpensive office supply items made with this fine mesh aluminum screen. I did use a smooth bumped throttle body to air bridge coupling and better clamps. It sounds as good as the BLACKWING, gets no codes, but doesn't look as sexy as an after market intake. I increased the oem opening from 10 square inches to about 25 square inches.
This is what I came up with...
Old Dec 3, 2007 | 11:53 AM
cobrakraiger
Wow that looks awesome! I dont really have talent for something like that though.
To Confused
Old Dec 3, 2007 | 12:04 PM
hotwheels57
A DREMEL with cut off wheel, a straight edge, tape or colored marker to outline the defined area to cut, medium sanding block, the screen, heavy duty scissors/shears to cut the screen, some careful bending against a straight edge and some silicone adhesive is all it takes. The bottom side of a Z06 has vanes which I used as a guide.
You can use your oem filter lid or buy one inexpensively off another member or EBAY.
Most members tend to go through several different intakes. That gets expensive even if buying used. This cost me less than $10 and an hour of my time...priceless! It might serve you until you find exactly the after market intake that you're looking for.
Old Dec 3, 2007 | 01:24 PM
mqqn's Avatar
mqqn
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04-'05-'06-'07-'11
Hi cobrakraiger -
One of the best and cheapest CAI's I have seen is the flip-tie mod.
It is simply the stock airbox, lid removed, air filter element help in place with zip-ties, and flipped upside down.
Cut out a rectagular hole to line up with the filter element, and viola.
Cold air intake for the cost of a few zip ties and some time.
The rad shroud you are cutting is easily and cheaply replaced for those worried about a bloomington gold in the future lol.....
I personally have a Halltech TRAP on my Z, and a twin-ram on the wifes 99 coupe. The Halltech is harder to maintain, and both ultimately provide more airflow than the stock maf can flow.
best regards -
mqqn
Old Dec 3, 2007 | 02:19 PM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
FYI on a Z06 those two front screen flow outside air directly to your intake... put a leaf blower to them w/ the hood up and see what I mean.
Any aftermarket filter will provide equal gains at speed. Some CAIs that are sealed to get only outside air (Vararam, Vortex Rammer, etc.) will dyno higher because they're not getting underhood air, but at speed it all equalizes.
Many on here beleive in the myth of ram air, but it's just colder air. I have a vortex rammer on mine because I've had it for 4 years and it was the hot ticket back then. We installed a Halltech on my father's Z16. Having to do it over I'd install a Halltech or a blackwing and call it a day.
