BMW JACK experience!
Old Dec 3, 2007 | 05:51 PM
Smoky2's Avatar
Smoky2
Originally Posted by Doug@MorosoPerformance
Bmw and Mercedes use bolts instead of studs. The axle is threaded to accept the wheel bolts. It is a real pain to hold the wheel up , locate the bolt hole and get the bolt started.
That's why they include one stud, with a smooth surface that you put in first, then hang the wheel on it, and put in the bolts, take out the stud, insert the last bolt, and it's all done.
Old Dec 3, 2007 | 07:55 PM
TEXHAWK0's Avatar
TEXHAWK0
A forum member was supplying these for $50, and a lot of members bought them, including me. I modified an aluminum jacking puck by cutting a slot in it to fit the nylon pad on the jack. I was not worried about the nylon marring anything. I was afraid on a roadside surface, the jack might slip.
http://forums.corvetteforum.com/show...=mercedes+jack
C5 Frederik in Germany. Go straight to the source!
It will fit in the side compartment. That is where mine is, next to the air compressor kit.
Old Dec 3, 2007 | 08:25 PM
Bob CTS's Avatar
Bob CTS
V dub as well, all are a royal PITA to get started
