long term tire storage
Old Dec 4, 2007 | 07:34 AM
e-hodges's Avatar
e-hodges
St. Jude Donor '06-'09
Default long term tire storage
Does anyone know what the best way to store spare tires long term is?
Old Dec 4, 2007 | 07:35 AM
WvCorvette's Avatar
WvCorvette
Old Dec 4, 2007 | 10:41 AM
87SAM's Avatar
87SAM
From what I understand, it would be in a cool, dark area. Preferably standing upright.
Old Dec 4, 2007 | 10:51 AM
When I had two sets of wheels/tires, I would keep the spare set in the basement on an old piece of carpet. They were stacked flat on top of each other with a piece of cardboard in between each tire. Seemed to store OK that way - I would keep them like that for about 6 months that way.
Old Dec 4, 2007 | 10:55 AM
GettReal's Avatar
GettReal
If you can.. off the ground (see pic) Otherwise I've heard put cardboard/carpet on the ground and stack them with normal air pressure.
Old Dec 4, 2007 | 11:03 AM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
I would also wash them thoroughly to remove all of the oxidized rubber, and then treat the tires with a good quality rubber treatment (and I don't mean goopy tire shire). I mean something like Meguiars #40, Adams Vinyl & Rubber Treatment, etc. Key is to keep them away from UV light to prevent oxidation and drying out.
vetfeva2's Avatar
vetfeva2
WOW, where do i get a set of those wall mounted tire holders?
Old Dec 4, 2007 | 01:03 PM
e-hodges's Avatar
e-hodges
what I have is a set of GY SC's that are unmounted, should I stack them or stand them upright. I don't want to deform them to much, I wont need them for a while (yr +) since Gieco just bought me a new set as part of a claim.
Ive already coated with a good silicone treatment.
Old Dec 4, 2007 | 01:11 PM
Beau's Avatar
Beau
I stack mine with cardboard in between the tires, but I have been told to lower the air pressure to around 15 or 20. So should I leave them with normal air pressure than? anyone?
Old Dec 4, 2007 | 01:45 PM
blacksedan87
If you are laying them flat or hanging them off the ground, then I would leave about 20lbs in them. If you are going to stand them up - I'd fill them with 30lbs. Of course - my opinion.......
Old Dec 4, 2007 | 06:08 PM
87SAM's Avatar
87SAM
Some tips from a couple tire manufactures.
http://www.conti-online.com/generato...torage_en.html
http://www.yokohamatire.com/pdf/tsb-112102.pdf
Old Dec 4, 2007 | 09:45 PM
BitViper's Avatar
BitViper
And drop the pressure down to 10psi using black plastic bags jwill also help keep air fluctuations from drying them out
Old Dec 5, 2007 | 07:46 AM
e-hodges's Avatar
e-hodges
As I said these tires are not mounted as in no wheels and NO AIR
should I stack or lay them flat?
Old Dec 5, 2007 | 09:52 AM
87SAM's Avatar
87SAM
Old Dec 5, 2007 | 10:13 AM
e-hodges's Avatar
e-hodges
Thats what I was looking for, thanks a bunch.
To long term tire storage
