torque and pressure
Old Dec 4, 2007 | 04:22 PM
Dave concrete's Avatar
Dave concrete
Default torque and pressure
Doe's anyone know what the ft lbs the Z06 factory rims get torqued at? Also what is the deal do you follow GM 30psi all around for tires or what the tire manufacture says or somewhere in the middle.
Old Dec 4, 2007 | 04:54 PM
Slow Z06's Avatar
Slow Z06
I use 100 ft.lbs TQ in a cross pattern. Front I run 32 cold and rear I run 30 cold. I also have stock badyears on front and DR's on the rear.
hope that helps some
Old Dec 4, 2007 | 05:26 PM
100 ft lbs is the setting and GM recommends 30 psi cold. I try to go 30 psi hot so that comes out to about 28 psi cold.
Old Dec 4, 2007 | 05:34 PM
2K14C7's Avatar
2K14C7
C7 of Year Finalist (stock) 2019
2018 C7 of Year Finalist
I set mine to 28 psi cold also.
I torque my lugs in the star pattern in three stages. 40-70-100 ft lbs
Old Dec 4, 2007 | 09:15 PM
Dave concrete
Thanks, I'm installing nitto 555R11 R extreme and I'm excited and my fingers are crossed these tires are the answer to my love for the twistys and the need for straight line performance.
Old Dec 4, 2007 | 09:43 PM
Oldvetter's Avatar
Oldvetter
I run 30 psi front, 28 psi rear on C5 Coupe. I get 55,000 miles fron fronts and 45,000 miles from rears, using OEM Goodyear Run Flats.
100 ft-lbs torque, drive 50-100 miles and re-torque.
Old Dec 4, 2007 | 10:26 PM
95vettski's Avatar
95vettski
Please post your thoughts on the new tires when you get a chance. I need to replace my F1's and I'm considering some Nittos. I have no traction till fourth gear, need some better tires!
To torque and pressure
