The Borla Thread. What'cha Running?
Old Dec 6, 2007 | 10:47 AM
  #41
Speeed-Racer's Avatar
Speeed-Racer
St. Jude Donor '12-'13-'14-'15-'16-'17
Originally Posted by csexton
Stingers rock. Had to take mine off after the ARH LT and racing cats install
Chuck
Chuck, I think I'm in the same boat you were. I have round quad 4 1/2" stingers with LG LTs and high flow cats. I have a good bit of insulation and it is about as loud as I would want. I like it at WOT, but wish it was a bit quieter ~2000 rpms. It has been descibed as "race car loud"
I am about to pull the trigger on a fairly large cam. It will be interesting to see what it sounds like after that. I am considering doing the A&A mod with Ti on the stockers. Still debating .
Old Dec 6, 2007 | 11:03 AM
  #42
C_O_R_V_E_T_T_E's Avatar
C_O_R_V_E_T_T_E
Default Thanks
Originally Posted by Cobra4B
Not with 2 tips... it's easy! If you don't have a friend to help, then get a floor jack and a piece of wood that'll span the 2 tips but fit in the bumper recess.
Loosed the connections then jack them a little higher than where you want them and crank the fittings down.
Works nicely for me, but I've found them very easy to allign and keep alligned. I can even access the one clamp w/ the car still on the ground an dmove the tip up/down.
Thanks! I will probably try that out when i get a chance. These were on the car when i bought it but that 1/4" difference is enough to drive me crazy!
