How to secure exterior window trim?
Old Dec 5, 2007 | 11:07 AM
lockmart's Avatar
lockmart
Default How to secure exterior window trim?
I've had a vibration noise coming from my car when the stereo hits bass (in addition to the Bose rattle) and thought it was my door panel. After listening to it a little longer and putting the window down etc. I've concluded it's the loose black trim around the outside of the window. What adhesive should I use to secure it? There is much more play than the other side so it's loose for sure.
Old Dec 5, 2007 | 11:51 AM
UAE-Vette's Avatar
UAE-Vette
It is the vibration of the Wing Mirror.
I got the 2004 CE and it is for defo the wing mirror buzzing away
Old Dec 5, 2007 | 12:45 PM
lockmart's Avatar
lockmart
The vibration goes away with the window down and it sounds stronger close to the seat area, so I think it's the actual plastic trim piece itself loose and hitting against the glass. I'll have to keep an eye out for the side mirror for future reference, but so far so good.
If I can fix the trim piece and my bose emblems I might have a shot at listening to the stereo without all kinds of interior noises, what a concept!
Old Dec 5, 2007 | 01:19 PM
z28flash's Avatar
z28flash
No expert here, but there is adhesive designed for window trim, I think I bought mine at the local auto store. Just be careful with it, and watch for any seeping, you want it to be neat and tidy!
Old Dec 5, 2007 | 01:21 PM
Speeed-Racer's Avatar
Speeed-Racer
St. Jude Donor '12-'13-'14-'15-'16-'17
3M 90, spray adhesive?
Old Dec 5, 2007 | 01:42 PM
Kale's Avatar
Kale
I have this issue... in fact my midbass speakers are slowly destroying my doors. :/
I tried silicone glue, but it wouldn't stay. Right now its held in place by double sided mounting tape.
Old Dec 5, 2007 | 05:13 PM
lockmart's Avatar
lockmart
Good idea, I might try that and see how it goes instead of glue. I'm nervous about using glue and getting it on the paint during application.
Might try glue on the bose emblems and see how that goes. Really would like to listen to the stereo without these freakin rattles.
Old Dec 6, 2007 | 02:01 AM
Kale's Avatar
Kale
I used clear adhesive silicone "household glues" to glue emblems on. Well, I removed the Bose emblems and put Dynaudio emblem in place. Has held very well.
I also used this stuff to hold the door pins in place, keep the styro noise plug from rattling... etc etc.
Sadly, my door speakers rattle everything on my car, so I feel like I'm chasing my tail :/
Old Dec 9, 2007 | 02:46 PM
superwaddle's Avatar
superwaddle
4th Gear
I have very similar door noise from the Bose speakers. I also haven't found much of a workaround, except of course turning the bass down a bit. Novel concept, I know...I know...
Old Dec 10, 2007 | 10:30 PM
lockmart's Avatar
lockmart
That's what is so surprising, it makes the sound with the bass neutralized so go figure. Not a very solid design.
Old Dec 10, 2007 | 11:02 PM
Jacks02's Avatar
Jacks02
You guys drive Vettes -- and actually listen to the radio instead of that glorious motor?
Old Dec 10, 2007 | 11:32 PM
10U 99's Avatar
10U 99
St. Jude Donor '08-'09
try 3M weatherstrip adhesive 8011. comes in a tube, it's black and will sick just about anything to anything
Old Dec 11, 2007 | 10:49 AM
lockmart's Avatar
lockmart
Thanks for another tip, maybe I'll pick some up. I was sure that was the source given it goes away when the window is down but I looked a little closer and it might be the plastic trim on the inside next to the window. The weather stripping had been jammed in their by the former owner...probably as a stop gap. I noticed it only after putting it back in place (course it was within the first week anyway so tough to tell). I might try putting some rubber and adhesive behind the panel. The search contines. I like just listening to the engine too, but sometimes I want to drown out my ac vents which are rattling....ugh. I know it's a Corvette but come one. The vents are much quieter when moved to the far right or left though. Still love the car though.
Old Dec 11, 2007 | 09:26 PM
spiral04's Avatar
spiral04
I just ended up taking off the Bose emblems.
To How to secure exterior window trim?
