.......ok......well this is a private sale and hes not a reputable wheel dealer so anyway back to the question does anyone know if these will fit a c5?
Your 9" wheel is probably 10" wide (for real). It is tough to use offset to fit wheels. Backspacing is prefered, as it is a measurement (where as offset is a calculation). Backspacing is key. I think if you Google or search on here, you will be able to figure out what offset or backspacing will get those wheels tucked in proper w/o rubbing.
Good luck.
Again, sorry for the first reply!
OEM 18x8.5 wheel (9.5" wide?) has 54mm offset or 6.95" backspacing (or 2.55" front spacing)
The 9" wheel (well, 10") would need 10" - 2.55" to have the same distance from the wheel hub face (that mates to the rotor hat) to the front lip... or 7.45" of backspacing.
I hope somebody else will verify and check my calculations for me and you!
