New speed bump problem.
Old Dec 6, 2007 | 01:09 PM
UAE-Vette's Avatar
UAE-Vette
Default New speed bump problem.
My car returned this week from its regular check up at the stealership.
However while driving over two speed bumps that i drive over every day, I heard the black rubber scrape... when i got to the second bump i heard the same movement of the front black rubber but then a horrible scrape of under side.
Now my car is stock on stock shocks and stock Egal F1's. The garage would have had the tyres off to inspect the brake disk etc but why would the car now scrape over speed bumps?
I am a tech noob could they have forgotten something?
Look forward to your help... will call garage tomorrow
Old Dec 6, 2007 | 01:11 PM
hotwheels57's Avatar
hotwheels57
Have the speed bumps been "improved" since the last time you drove over them? Maybe just the angle or exact point of driving over the speed bumps has changed?
Have you or your car gained weight? Sorry...
Old Dec 6, 2007 | 01:17 PM
UAE-Vette's Avatar
UAE-Vette
Er no - speed bumps are the same crap ones that have been there nice and worn, like always i attack them straight ahead.
The car is empty no golf clubs or anything in it. Unless the new stamp in my service book ways a ton...
Only changes are the garage has pumped the tyres up to 32 PSI front and Back. From the 30 I normally have them at.. if anything this adds height...
Could something in the suspension be broken? Could they have adjusted something. Have they forgot to bolt something back in during the service?
eek
Old Dec 6, 2007 | 01:36 PM
way2nutz's Avatar
way2nutz
Make sure they didnt leave the jacking pucks in place......
Old Dec 6, 2007 | 02:14 PM
bucwheat's Avatar
bucwheat
Mine always scrapes on speed bumps.check to see if they pulled the center black spoiler loose,they are spring loaded,may have broken one.
Old Dec 6, 2007 | 02:19 PM
jmorr649's Avatar
jmorr649
That is interesting...I actually don't ever scrape on speed bumps...but I also always go a touch sideways over them.
Old Dec 6, 2007 | 03:04 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
How would the pucks make the front dam drag on the bumps? Just wondering. They don't weight that much..
Old Dec 6, 2007 | 03:05 PM
Hard to say, but if I had to guess, I'd say that they might have left something loose in the suspension. Might be a good idea to go back to them and have them give the car a good look over.
Old Dec 6, 2007 | 03:31 PM
rpm462's Avatar
rpm462
Did you have the oil changed? They might have put the wrong oil filter on and it extends down below the car too far.
Old Dec 6, 2007 | 03:35 PM
R Devil's Avatar
R Devil
Old Dec 6, 2007 | 06:06 PM
way2nutz's Avatar
way2nutz
Ya, excessive puck weight thats it.
Speaking from experience.... a left in puck grinding on a speed bump sounds a lot like the front air dam scraping.
Ok, I've admitted out loud that I left them in once, let the chastising begin.
Old Dec 6, 2007 | 08:46 PM
D2Brewing's Avatar
D2Brewing
Bad Corvette driver, bad!!! OK - consider yourself chastised...
Old Dec 6, 2007 | 10:20 PM
bestvettever's Avatar
bestvettever
Default Maybe Lower
Hi If the shop did suspension work, they may have done an alignment and checked the height, and lowered it a smidge. Usually an alignment is called for after most suspension work, and a height check is called for with an alignment
Luck
Old Dec 6, 2007 | 10:33 PM
Kale's Avatar
Kale
tires are low?
To New speed bump problem.
