Painting radio bezel
How would a guy go about painting the radio bezel and the other plastic dash parts? What do you use to paint the lower door panels?
Thanks Guys
Thanks Guys
Prime it with a good primer, then hit it with paint. SEM is decent stuff for satin black. Paintscratch is expensive but a better match.
I textured and painted my a-pillars after remolding them.
Location: Mississauga, Ontario Corvettes were built to be driven...not trailered
1 Post
St Jude Donor '07-'08-'09
SEM Texture coat. $17.99 a can. Alternatively you can use spray bedliner in a can for $6.49 but it comes out much chunkier.
Makes a sort of "textured plastic look" with the stock cap
I used a cap from a rubberized undercoating can, and it came out much thicker - more like leather or vinyl look.
This is with naked texture spray, before hitting it with 400grit to smooth it down:
My car is in the process of being painted right now so i thought i would pull the plastic parts off and prep them myself if i knew how.I want to have them painted the same color as the car.What about the roughness on the parts?
Received 19,837 Likes
'20-'21-'22-'23-'24
I've got a few Word files that I created from past posts here on the forum about painting interior pieces. Be glad to share them with you if you PM me your e-mail address.
Keep in mind a lot of the parts are covered in vinyl.
Kale, I really like your tweets in the A pillars, that's on my list. Good advise on the textured base paint. Lowes is my source for textured paint.
old55: Be sure to temporarily mount with a strap/tape/whatever before fixing them. 1/8" of difference, or even 5 degrees is a HUGE sound difference. This is my second set :/
RadioFlyer:
SEM is not available at home depot... Gotta find a specialty paint store.
RadioFlyer:
If you want a smooth finish, you have a ton of sanding ahead of you. Start with ~200 grit to level it, 400 grit to smooth it out.. then you can start sanding for primer, paint.. clear.
