[Z06] FAST Intake question
Old Dec 7, 2007 | 03:49 AM
MYLS6's Avatar
MYLS6
Default FAST Intake question
I have emailed FAST Tech a few times with no replies..exactely what gaskets will I need to order to install the intake? it will be matted up to the Nick Williams 90mm TB..also I have read a few places about some valley bolts will I need them also for a normal install or is that something different? thanks!!
oh install will be on '03 Z06 if that info is needed..thanks!!
Old Dec 7, 2007 | 11:00 AM
SilentFright's Avatar
SilentFright
From: Arlington Texas, originally from San Angelo, TX
You will need to order the 90mm throttle body O-ring and a set of intake manifold to head seals. The low-profile valley cover bolts come with the manifold and are required for the install because the stock bolts will contact the bottom of the intake. If the intake is torqued down with the stock valley bolts in place you will most likely crack the intake.
Old Dec 8, 2007 | 07:26 AM
MYLS6's Avatar
MYLS6
thanks a bunch!!
To FAST Intake question
