Time for suspension work
Old Dec 7, 2007 | 11:40 AM
Ben01C5's Avatar
Ben01C5
Default Time for suspension work
It is time to upgrade/replace the stock suspension on my 01 Coupe. I have the magnetic ride crap. Can i not just swap to Z06 shocks, or do I have to get special shocks that will work with the Magnetic suspension stuff.
Any help is appreciated.
Ben
Old Dec 7, 2007 | 12:12 PM
Zenak's Avatar
Zenak
Terminal Vette Addict
not sure if you need to get special shocks..
but the new C6 z06 shocks are a good deal, as are the billsteins sports.
Don't go for the OEM replacement, thats silly.
Old Dec 7, 2007 | 03:18 PM
Last C5's Avatar
Last C5
If you swap out to standard shocks, Z06 or whatever, you're going to need some simulator resistors to plug in your old shock wiring to keep from getting codes. I don't know whether those can be tuned out or not.
Old Dec 12, 2007 | 02:22 PM
Ben01C5's Avatar
Ben01C5
Thanks for the info guys.
I know someone has to have replaced thier shocks on a coupe with the magnetic ride to a different shock.
Help me out.
Old Dec 12, 2007 | 02:29 PM
Itallian33's Avatar
Itallian33
The c6 zo6 shocks are a great deal and they will bolt right up to your coupe. I have the selective ride controll and it sucks. There is no reason to keep it on you car. To stop the car from getting codes when you run, you must either turn the codes off, or get resistor to simulate the missing shocks.
Old Dec 18, 2007 | 02:04 PM
Ben01C5's Avatar
Ben01C5
One other question would be if I should go with C6 Z06 shocks, or get the Bilstein Sports?
Old Dec 18, 2007 | 04:20 PM
SinghZvette's Avatar
SinghZvette
My F45 shocks needed the following simulators
http://www.casperselectronics.com/mm...ry_Code=CORVC4
Old Dec 18, 2007 | 07:11 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
I would check out the Pfadt coilover and sways to tighten up your ride.
Pfadt also sells simulators for the magnetic ride. If your still running the runcraps you ought to think about changing them out.
These changes will make your car out handle a ferrari.
Old Dec 18, 2007 | 07:22 PM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
You'll find everything you need right here
http://www.customcorvetteaccessories...t/c5pfadt.html
Peace
Chip
__________________
..................Click for
Old Dec 18, 2007 | 08:15 PM
Ben01C5's Avatar
Ben01C5
aLL THE CRAP I HAVE DONE TO MY CAR AND i HAVE NEVER taken it to the drags or road course. The price of the Pfadt's are way more then i would spend for suspension parts especially now that the car is a weekend warrior at best.
I think the bilsteins will work fine for me. I do appreciate the links and the info though.
Ben
Old Dec 18, 2007 | 08:24 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Ben
At a minimum add in a set of Metal end link on your sway bar ends.
Old Dec 18, 2007 | 08:34 PM
CTD's Avatar
CTD
We now have established budget & priorities, makes it easier to help.
Old Dec 20, 2007 | 02:54 PM
Ben01C5's Avatar
Ben01C5
Well, I went ahead and ordered the Bilstein Sports from Randy at DRM. They were having a special so it worked out great.
Old Dec 20, 2007 | 03:58 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Make sure you do the metal end links, if you have a 2001 or earlier vette. The shocks won't help much as the plastic end links will just give way.
Old Dec 20, 2007 | 04:20 PM
DefenderC5's Avatar
DefenderC5
Also get some Z06 swaybars/aluminum endlinks from Gene at GMpartshouse.com I got mine for about 240 bucks. I installed them when I did my Bilsteins. Night and day improvement for only about $550for everything (shocks, sways, links, bushings)... I highly recommend doing it all together. You'll already be under there... might as well?
To Time for suspension work
