I painted my calipers Red a few months ago,(see pictures) and because my baby is also my DD, I have accumulated a good amount of rock chips on the calipers, and they look horrible with sections of the paint missing.
Without the obvious answer of powdercoating, what is the best way to repaint them?
Do I just paint over whats there... or do i need to strip the paint first, and then start from scratch? If i do need to strip, how do I do that.
Please keep in mind that taking the caliper off is not an option as this is a DIY fix for me.
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
As with any painting you should re-prep everything, Not sure what kind of paint you used, But I would use epoxy paint and be sure the surface is clean and well prepaired. and prime ...
