I finished installing my LT's saturday and just got to drive it last night for the first time. I am sure I have done something simple and stupid but the car is running rough and missing. I pulled the codes and got-
p0300-engine misfire
b2282-batt 1 fault
b2284-batt 2 fault
u1064-loss of bcm
I am getting a r2283 and r2285, I can't find these codes, any help with the codes would be great. Also any other suggestions for what I might have done would be good too.
I suspect a low battery or battery failure (or perhaps a disconnect) may be able to throw the following codes, which may be related to module communications issues due to low or no voltage and may or may not have anything to do with the poor running.
If the car sounds like its missing you need to go back and recheck all of the wires connection. I unplugged one of mine to install the oil dipstick tube and forgot to plug it back in on the test drive. there is a definite sound to missing a cylinder. Also, if its a battery code recheck the connection there as well. so recheck and let us know!!
