This is my first post ever Ok i bought rear brake scoops & cooling ducts for my 2000 coupe from GM SPO.For a great price employee discount. Problem is i do not have template to cut those two scary holes in my baby.Do any of you know what i can do or where i can get a template. I'am asking my C5 buds for HELP .Sorry for the long winded post thank's.
Thank you ajg 1915!! holes are off but played around with it and got it to fit four templates later. Now it is time for the cutting wish me luck
I never used those templates as I have some paper one's, that I got when I bought some ducts off of another CF member. Only problem is that they are on 11 x 17 paper and I don't have a scanner big enough to scan them in.
BEWARE. This is a very common mistake made by many. When placing the template on your scoop and thinking the holes are not correct is wrong. Very common mistake is you are not allowing for the curve of the body when trying to match these two up. The holes on the templates ARE correct....
Thanks for the tip !!!! ya know i wondered about that when i was looking at it against the car. I wonder if anyone has had luck with those template's. I have not done this yet want to make sure first. I have a two post left in my pole barn should make things easy i hope Thank's guys the people on the forum are the best.
