Caravaggio Steering Wheel
Do you like it? Overall opinions good and bad
Have you had any issues with swapping it for the stock wheel? Airbag codes or problems...
And did you go for leather or Alcantara?
Thanks in advance for helping me spend my money!
As for shows, etc. Not as many people notice as I expected. They see the leather is custom, but don't always notice the grips. Still, I love it.
If you did the suede, I bet it would get noticed more. I also recommend going with some other pieces at the same time to help finish the look. Personally, I'm saving my pennies for the Carvaggio sport seats (among many other mods....).
I haven't had any problems with codes, fit, etc. I had a local Vette Mechanic do the install. It isn't perfectly straight, but I'll have that corrected with the next alignment.
Here's some pics. I don't have any from head on.
If you really want to see something cool - check out Carvaggio's C6 sport wheel.
chris
LOL you trying to keep up with the wife's car ??? I think it would look good in your car. Look at my avatar...bought me a 61 while you been gone.Joe
I've tried many times to convince John to customize an adaptor to get a C6 steering wheel to fit our C5's, but he suspects that the RND for it would not be worth the cost/profit ratio.
So I settled for a C5 steering wheel, had it wrapped in alcantra like the Ferrari's and Lambo's.
The thicker than stock steering wheel really gives it a nice feel.
I'm making enough, gotta keep my car fresh so I don't go buy a C6 Z06 and put myself in the poor house
Nice addition to the garage there Joe, can't wait to see it when I get back.
How is the suede holding up? I am really thinking about getting this set-up but I'm concerned about the suede getting spots or developing wear patterns since my Z is practically a daily driver. Thanks for the help.
John folds the leather around the seam points of the plastic front of the air bag. I'm not sure if John's ever tested it, but the seams are there, so I doubt with the force of an airbag going off it would be impeded in any way by the leather seams. If you look carefully at my pic, you can see them.
Apparently, only the wheel-side spline of the column is different (I suspect it was deliberate by GM to make it not backwards-compatible). So IN THEORY, you could swap in a C6 column to a C5 because the rack-side spline is the same. You'd also need AT LEAST to make the steering position sensor work, as well as marry the airbag electronics since the C6 bag is smaller than the C5. I'm not saying it can't be done - ANYTHING can be done with enough dough. Even if you made an adapter, you'd still have the airbag electronics to deal with, and from what I understand, the C6 has 'smart airbag' technology that the C5 doesn't have, so it might be tricky. [Although you'd think the bang wire is the bang wire, right?]
This has sort of been on the back burner for me as far as trying to find the parts and explore this option -- I have several other car-project sticks in the fire at this point. The Caravaggio C6 wheel IS amazing, though!!
It's just a cooler wheel.
chris
