Dealership Damage - What to Expect?
Old Dec 14, 2007 | 12:58 AM
Choreo's Avatar
Choreo
Default Dealership Damage - What to Expect?
My car has been at the dealership now for 2-1/2 weeks for warranty work under my extended GMPP. The last thing on the list apparently involved them changing out both side mirror motor/actuators inside the mirror housings. To do this they had to remove the mirror glass from each housing, replace the actuators and then replace the mirror glass,
Here is the problem. About three years ago I replaced the mirror glass with Muth Signal Mirrors (http://www.kwmuth.com/products/kits/220-0190.htm). The dealership informed me today that they cracked one of the mirrors on the passenger side during reinstallation. They said they had ordered a GM stock replacement, but that would mean I have lost all the functionality of the upgrade. Muth does not warrant against breakage due to poor installation. I had no problem installing these myself three years ago with no breakage. I called Muth today and I purchased a replacement mirror for the passenger side ($114 - more than my service deductable!).
My question is should I expect the dealership to pay for this replacement to restore the car to the condition in which I presented it - or am I just hosed?
Old Dec 14, 2007 | 01:07 AM
FUN LS1's Avatar
FUN LS1
St. Jude Donor '08-'09
You should expect them to return the car to you in the condition you dropped it off. Any deviation is no fault of your own and the service manager should have told you they would not work on any modified parts.
Old Dec 14, 2007 | 01:27 AM
Choreo's Avatar
Choreo
Although the Muth Signal mirrors were not standard on a C5, they are standard on quite a few cars as a factory installed item. When I spoke with Muth today, they said that (since they install a lot of these at their service centers) the Muth mirrors are no more fragile than the GM factory mirrors (which the dealership is claiming). Muth said they have had just as many factory mirrors break on them as their own. Furthermore, the GM Technician today told me that the GM replacement mirror glass for one side is $360!!! - way more than the Muth Mirrors if that is true.
Old Dec 14, 2007 | 01:37 AM
Bill Dearborn's Avatar
Bill Dearborn
You should not have purchased the glass yourself. You should have had that discussion with the Service Writer and Manager. Probably what happened is somebody dropped the glass and they just ordered what the parts department said should be ordered. When they called you should have said to them "What about my special mirror and have you contacted Muth for a replacement".
If you can return the one you ordered try getting the dealership to pony up buying the part they broke. They are not going to buy a part from you.
Bill
Old Dec 14, 2007 | 01:57 AM
Choreo's Avatar
Choreo
Bill
Good point. I will try that tomorrow. I was just beat down waiting on this car to get out of the shop and finally decided if that is all it takes to get the car back, I will just take the broken mirror and get back on the road and fix it myself.
Old Dec 14, 2007 | 07:08 AM
Junkman2008's Avatar
Junkman2008
There's no way in hell that they would give me my car back without fixing that mirror. Or, they'd end up in small claims court for the cost of the mirror and the labor to have ANOTHER shop install them.
Old Dec 14, 2007 | 08:20 AM
robsc501's Avatar
robsc501
HI There,
The dealer just did ordered what they thought was the correct mirror.
They had no way of knowing it was a muth unless muths name or p/n was stamped on it, but your mirror was probably was broken into a million pieces & unreadable.But they should have known as you have more wires connectors than a stock mirror correct? Bring it to the service mangers attention in a nice way.(Being pissed off never gets you any place)that they are saving $246 dollars by buying the modified mirror verses the gm mirror. Ask them to order the mirror from muth & pay for it & cover the installation.A good dealer will do this with out a hassle. After all it was their screw up.Sounds to me they don't have corvette mechanics. Just mechanics that occasionally work on a corvette.If thats the case get them to pay for the part & I would install it myself. If muth breaks them then, they would probably break it again.You must know the tricks to the installation.
When you get this resolved I would appreciate detailed instructions from you on installing this item & not the general data from muths website.
The best to you.
merry christmas.
robsc5vette
Old Dec 14, 2007 | 08:39 AM
Bob CTS's Avatar
Bob CTS
Go in with the invoice and ask for the service manager and explain very nicely what you are requesting. Show him what you paid, you might get it all, half or nothing. In case of the latter write GM a letter. It has worked for me.
Old Dec 14, 2007 | 09:55 AM
Junkman2008
Originally Posted by robsc501
HI There,
The best to you.
merry christmas.
robsc5vette
That price for the stock mirror is what you and I pay, and of course the price that the dealer passes on to us. I bet the dealers get it for much less.
Old Dec 14, 2007 | 11:00 AM
Choreo's Avatar
Choreo
The best to you.
merry christmas.
robsc5vette
The only "trick" I used was to follow the Muth instructions. It is obvious from the design that you can only apply pressure to the center section of the mirror during installation. It was also obvious that pressure was applied to the outside of the mirror when the dealer tried to reinstall it - it was still in one piece, just shattered around the center support section. It would be pretty hard to break the mirror by applying only pressure to the part of the mirror that has the support pegs behind it, but if you put ANY pressure around the edges where there is no support, they will break for sure. I was told by the dealership this morning that the proper procedure for installing the factory mirrors is to "bow" them during installation - I KNOW that isn't right.
The other thing is that you have to make sure all the pins in the back are perfectly aligned
These Muth mirrors are standard on over 1 million factory vehicles in 2007 alone - so somebody is getting them on (and so did I).
Old Dec 14, 2007 | 11:10 AM
z06Bigbird's Avatar
z06Bigbird
Sit with service mgr. Politely explain situation to him/her. See if he/she can horsetrade parts cost or labor on a future visit. Dealer would rather not shell out money, but he/she can offer to make you happy via bartering. Works for me. I believe it is easier for dealer to come up with parts cost than labor since he still has to pay mechanic.
This is great opportunity for you to become close to service mgr.
e. g., Ask for a big disc on one or two tires.
Old Dec 14, 2007 | 11:21 AM
Choreo's Avatar
Choreo
No doubt. Just like some of these little computers they have installed that basically run one set program continually costing more than a new Apple Macintosh that can run ANYTHING. They can "claim" that they are "specific" and build less - I can see that, maybe, but these "computers" do very little in the scheme of things - I would be shocked if the most expensive one actually cost $100 - technology and all.
Old Dec 14, 2007 | 03:56 PM
jaygood's Avatar
jaygood
I think they are responsible for replacing it the way it was. The wouldn't replace a aftermarket wheel with a stock one, would they?
Old Dec 14, 2007 | 07:16 PM
jayzze's Avatar
jayzze
Default stealoership damage
the dealer cracked breathlesss fixed head light kit and they replaced it
with out a hassel but when i bought it back to replace it they had fixed it and proceded to smack the vette up for over 4 grand and this time did not want to pay for it until the lawyers letter came good luck
Old Dec 14, 2007 | 08:24 PM
Jacks02's Avatar
Jacks02
The Service Manager can be your best friend -- or worst nightmare. Put on your happy face, sit down with him, and explain your perception of what happened and what should be done. The ball is then in his court -- and he's the decision-maker in the most profitable department in the store. Next step above him is the General Manager, and above him, the owner. If necessary, diplomatically follow this chain of command. If you don't get the results you believe are due, then it's letter writing time to GM Customer Service. They've been good to me, and should be to you, too. Good luck.
Old Dec 14, 2007 | 08:33 PM
b_pappy's Avatar
b_pappy
From: the GOCC are everywhere, even back from "band camp"
I agree, it also helps to have a relationship before something like this happens though. Sit down and try and come to an amicable arrangement.
Bruce
To Dealership Damage - What to Expect?
