Mint 2000
Old Dec 14, 2007 | 03:00 PM
Arnie Siegel's Avatar
Arnie Siegel
1st Gear
Default Mint 2000
Love my Vet we all do, however I have had an ongoing problem that the dealer can't figure out and I can use some help. The drivers seat memory does not hold. I have replaced the sensors twice, checked the wiring, done everything that I can think of. The seat must be readjusted EVERY time I get in the car.It never goes back to my settings.
It operates fine, ie up, down, in out,etc., but the memory does not work. The drivers mirror must be adjusted each time as well. Any suggestions from anyone will be appreciated.
Old Dec 14, 2007 | 08:32 PM
c5streak's Avatar
c5streak
My first guess would be check ALL of your ground connections. Do asearch, there are tons of threads on bad grounds and the problems they cause. Also, a weak or failing battery can wreak havoc on our cars electrical accessories.
Anyone Else?
Old Dec 14, 2007 | 08:46 PM
Jacks02's Avatar
Jacks02
Old Dec 14, 2007 | 09:51 PM
roscoe118's Avatar
roscoe118
It could be as simple as the setting for the driver door switch is not the same as the Key Fob that you are using. Try setting one, two, and three (hold down both 1 & 2 to set 3) after you position the seat and mirror the way you want.
To Mint 2000
