Headlight motor weird things?????
http://forums.corvetteforum.com/show....php?t=1767764
hope this helps...
J
Myself, I just disconnected the bracket and turned the motor manually to the unused side. The motor does not revolve 180 degrees. I also have Rodney Dickman brass replacements for whenever I feel like replacing the plastic ones.
There are SOOOOO many posts on this forum about this issue.
Just go to the "search" menu
1) Look at the way the power wires are postitioned thru the Head light. So when you go back you'll know how to run the new wire to plug in you head light.
2) Notice which color wires are on which headlight plug.
3) once the light is in the open position, put a towel around the headlight opening so the ratchet will not scratch your paint.
4) stuff a towel inside the dealight opening to catch the nut and washer that might fall in.
I had to install the damn motor twice because I didn't pay attention to where the wires were positioned around the motor. Never-the-less it took 25 minutes for me and my neighbor to remove, install, remove and re-install... It's really simple...good Luck
Art Mejia
However, my mechanic disagreed. He called that plastic gear a suicide gear. He said it's job is to give out instead of the motor giving out. That makes sense in theory but I think he's wrong on this one. If the motor decides to over-crank the gear, I think its time to replace the motor anyway, or there's a problem somewhere else.
Anyone else ever heard of the "suicide gear" theory? To the OP, here's my headlight gear replacement instructions that even a kid could follow:
http://forums.corvetteforum.com/show....php?t=1823603
Here it is:http://www.bfranker.badz28.com/headlightfix/index.htm
Since putting this page up several years ago, I have received, no lie, probably over 1,000 pieces of email thanking me profusely for putting this page up describing how to fix the terrible ratcheting noise one hears one the stock nylon gear strips. The main problem, and why I get so many emails about this, is that the design is poor to begin with. There are no limit switches or anything "fancy" which stops the headlight motor when it goes up or down. There is simply the control module which senses a high amp/current draw and THEN shuts down juice going to the motor. So, each time you turn on/off your lights, the motor, for a split second, tries to continue to raise/lower the headlight even though it physically can't. This puts a lot of stress on the nylon gear and, since the same area of the gear always gets the stress, it often times doesn't take long for these to fail. And, when the nylon gear fails, it costs big $$$ to have it fixed. Out of the 1,000+ emails I've received, the average people have been quoted to have just ONE of these headlight motors replaced is over $300! Often times it is even over $400. Why GM thinks this is such a "valuable" piece is beyond me. I think it is nothing more than an easy money maker for GM and the dealers. GM makes a killing on the part and the dealer makes a killing on installing it. Yep, several people have been quoted $200 or more to install this motor and it takes, at most, 30 minutes with average tools. Very odd why they charge so much for this but, either way, I hope to put a little dent in their enormous profits for this item
