Read the recall (Steering Lock),,,,, NOW
Old Dec 18, 2007 | 07:38 AM
1slowride's Avatar
1slowride
Default Read the recall (Steering Lock),,,,, NOW
I did see the recall on the steering lock and talk to thr previous owner yesterday and he told me the recall had been done on the steering wheel lock, and I did call the dealership and they also tole me by VIN # my car had been done.
But...........
now all of a sudden, the steering wheel lock is lockiing everytime I remove the key.
Should it lock or NOT be able to?
Old Dec 18, 2007 | 07:42 AM
Bugaboo's Avatar
Bugaboo
It'd be real helpful to fill in your profile.......auto or 6 spd., location (members can suggest local help). Profile info is a good thing
Old Dec 18, 2007 | 07:45 AM
Tom/99's Avatar
Tom/99
Install a column lock bypass, and be done with it.
Old Dec 18, 2007 | 07:47 AM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
Yep, takes the actuator out of the equation.
Old Dec 18, 2007 | 08:28 AM
My understanding is that the latest fix will prevent the column from locking. If it was the initial recall for this problem, then yes, the column will still lock. I highly recommend just spending $50 or so and get a column lock bypass. Install is simple and you won't have to worry about the problem again.
Old Dec 18, 2007 | 08:56 AM
1slowride's Avatar
1slowride
Default Profile
Sorry about the profile, I will update it.
Car is a 02 Z06, and I was thinking when the recall was done that it would not allow the wheel to lock, I guess I was wrong.
Old Dec 18, 2007 | 09:05 AM
mrm1149's Avatar
mrm1149
I believe one of the later versions decided to install the (or remove) lockplate from 6 spds. also.
Old Dec 18, 2007 | 09:17 AM
Oldvetter's Avatar
Oldvetter
There are several revisions to this recall. Only the last one removes the locking plate on manuals. GM will only do one recall, UNLESS a Dealer determines your column is locked due to a failure of the recall, then they will re-do it. A lot of Dealers want to charge after the first recall.
You can always take it to a Dealer and see if they will remove the locking plate. All they can say is no. These recalls are so complicated, I might have missed something. Maybe you are entitled to have the locking plate removed? Anyway, GM is stopping all free recalls on this after early ( Feb or March) 2008, so if you are going to try to get a free recall, do it now.
I do agree that you should install an aftermarket CLB and be done with it, though.
To Read the recall (Steering Lock),,,,, NOW
