[Z06] wheel rash
Old Dec 19, 2007 | 01:42 AM
1ST VETT's Avatar
1ST VETT
3rd Gear
Default wheel rash
my '02 Z is in pristine condition with the exception of a small amount of rash on the right front and back wheels. Any suggestions on how to proceed to fix the rash. I am located in the Walnut Creek area in Northern California and would appreciate any feedback.
Old Dec 19, 2007 | 08:05 AM
only59's Avatar
only59
On my previous Aluminum wheel Vettes I used a dremel tool with several different bits, smoothed out the rash and it polished up nicely.
I am thinking the procedure is the same except now we have the special wheel paint to deal with , maybe mask very carefully and use an Airbrush when the rash is smoothed out to paint the surface. Very very light multiple coats of paint.
Certainly if you could pull the wheels and tires, this would be an easy project...but I ain't doin' that..and I too have a small amount of rash...
there is a thread around here somewhere with the wheel paint info...
good luck
t
Old Dec 19, 2007 | 01:24 PM
u4ick's Avatar
u4ick
Here in St.Louis there is a wheel place that will recondition the factory wheels to like new condition for $145 per wheel...........they said most of the cost is getting their machine set up so the cost would be for if the wheel has a slight blemish or really bad road rash.
Call around I'm sure there has to be a place similar where you live...
Old Dec 19, 2007 | 04:31 PM
1ST VETT's Avatar
1ST VETT
3rd Gear
Thanks for the feedback. I did order the paint from paintscratch. I will try the dremel approach and see if I can pull it off.
Old Dec 19, 2007 | 05:28 PM
Big Kidd's Avatar
Big Kidd
Originally Posted by u4ick
Here in St.Louis there is a wheel place that will recondition the factory wheels to like new condition for $145 per wheel............
Why would someone pay $145 for reconditioning, when you can buy a brand new wheel for $184.75??
http://www.finishlinewheels.com/spec...+Z06+SIZES%29/
Old Dec 19, 2007 | 08:09 PM
ruffian's Avatar
ruffian
I too am looking for place that does wheel repair/reconditioning here in San Jose bay area. Wheel Works says they have "a guy" who will do the work for about $250... meanwhile I have heard previously that there are indeed places around here charging $150/per.
Regarding buying a reproduction wheel. I've heard folks say they have problems with aftermarket wheels at high speed, shimmy/wobble. Does this also hold true for the Repro's?
Thanks in advance!
bob
Old Dec 20, 2007 | 01:33 AM
gnava00's Avatar
gnava00
Default wheel repair
There's a place in Hayward called Wheels America.
They do repairs for the Z06 OEM wheel for $125.
You can also buy OEM wheels from them.
I'd stay away from replicas. The OEM are extremely light and well worth keeping.
Check them out at:
http://www.fixrim.com/
Old Dec 20, 2007 | 01:42 AM
heavymetals's Avatar
heavymetals
Wheels of America
Fast turnaround.
Old Dec 20, 2007 | 10:42 AM
76texvette's Avatar
76texvette
Check them out at:
I just had two of my polished aluminum Z06 wheels done in Dallas
by Wheels America.
Both had curb rash by the previous owner.
They came out looking new ...could not tell they had had curb rash !!!
Old Dec 20, 2007 | 11:56 AM
u4ick's Avatar
u4ick
True, that is why I'm going to spend my money on other wheels.
But even if I was keeping the same wheel, I would wrather get these fixed than to buy a re-production wheel. (unless it was polished and same weight)
BaseballDude's Avatar
BaseballDude
One in Santa Fe Springs, CA...within an hour of my place.
Thanks for the reference, folks!
Old Dec 20, 2007 | 06:23 PM
ruffian's Avatar
ruffian
Thanks for the sources guys! bob
To wheel rash
