The coves..
Old Dec 19, 2007 | 09:31 AM
04 commemorative's Avatar
04 commemorative
St. Jude Donor '17
Default The coves..
Inside the coves in front fenders are some kind of flap...can you remove this and if you do will it let engine heat escape better thru them?
Old Dec 19, 2007 | 11:07 AM
DefenderC5's Avatar
DefenderC5
Don't know about those, but there is a weather strip between the hood and the windshield cowl that can be cut. Remove about 6" of material on both ends and it will allow some of the trapped air in the engine compartment to escape. It's about as effective as a free mod could be.
Old Dec 19, 2007 | 11:11 AM
phoenixfoundmac's Avatar
phoenixfoundmac
I wouldn't take out the one on the passenger side because it will make it easier for water to get on the pcm.
Old Dec 19, 2007 | 11:27 AM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
Wrong... removing that strip lets air go under the hood and will cause the hood to flutter. As air comes over the hood and hits the windshield it creats a high pressure area. W/o the strip it will in effect act as massive cowl induction and not do what you want.
I know... I tried it at VIR up to 160 mph. I promptly put it back in and all was normal.
Old Dec 19, 2007 | 11:32 AM
R Devil's Avatar
R Devil
I'm guessing that stuff was put there for a reason.
Old Dec 19, 2007 | 11:36 AM
Cobra4B's Avatar
Cobra4B
Also, you have no need to let heat better escape. Do you have a racing radiator? Do you race the car? Do you have twin turbos etc? If not the car is fine and enginered that way for a reason.
Old Dec 19, 2007 | 11:53 AM
10U 99's Avatar
10U 99
St. Jude Donor '08-'09
I've found that is usually the case.
Old Dec 19, 2007 | 11:30 PM
Yes, the flaps can be removed (held on with a couple of screws), but doubt it would help much with heat extraction.
Old Dec 20, 2007 | 09:16 AM
Cobra4B's Avatar
Cobra4B
^ Yes it's two screws on each fender... I have mine off for my re-paint. Just took them off a few days ago.
Old Dec 20, 2007 | 09:25 AM
04 commemorative
St. Jude Donor '17
No I do not race...
No I do not have twin turbos
Yes I know it was made that way....
Maybe...... I was just curious????????
Old Dec 20, 2007 | 12:05 PM
jdmvette's Avatar
jdmvette
Night Owl for life
i've ran w/o my driver's side for a couple years now. the engine heat is noticible thru the cove w/o the block.
Old Dec 20, 2007 | 02:19 PM
bucwheat's Avatar
bucwheat
Beat me to it,what he said.
Old Dec 20, 2007 | 02:28 PM
WetteVette's Avatar
WetteVette
Most of us are NOT mechanical engineers.
Old Dec 22, 2007 | 12:10 PM
04 commemorative
St. Jude Donor '17
To The coves..
