CAGS Shift Eliminator
Old Dec 19, 2007 | 08:15 PM
Schumpgl's Avatar
Schumpgl
2nd Gear
Default CAGS Shift Eliminator
I bought the shift eliminator and will be installing it on my 2003 Anniversary Vette.
Any good advice for lifting the Vette to installl this?
Old Dec 19, 2007 | 08:16 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Use pucks.
Old Dec 19, 2007 | 10:40 PM
Treads's Avatar
Treads
Theres a good DIY thread here on the forum, making approach boards, which will allow you to get a floor jack under both the front and the rear and lift each end up. I like the approach boards for oil changes and tire/wheel changes.
Or you could just use pucks and lift each side one at a time, which is all you need for the CAGS.
Old Dec 19, 2007 | 10:56 PM
Just use a good floor jack with a piece of wood and lift from the rear crossmember (plus use a pair of jack stands for added safety). Then you can crawl under the car and install the CAGS eliminator. Takes about 10 minutes from start to finish.
Old Dec 20, 2007 | 09:28 AM
04 commemorative's Avatar
04 commemorative
St. Jude Donor '17
Or back it to edge of driveway apron with *** end hanging over the street. It works.
Old Dec 20, 2007 | 09:30 AM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
jack stands any time you are going under the car
Old Dec 20, 2007 | 10:21 AM
Tom/99's Avatar
Tom/99
It took longer to jack my car up and crawl under it, than it does to install the CAGS eliminator.
Old Dec 20, 2007 | 10:43 AM
steve8's Avatar
steve8
Wait until the next oil change and all you have to add to it is about 20 seconds.
Old Dec 20, 2007 | 11:50 AM
hotwheels57's Avatar
hotwheels57
That's certainly the truth! Instead of using a plastic tie wrap to secure the widget to the transmission ear, use a rubber isolated clamp and a 1/4-20 bolt/nut. It'll keep it isolated enough to prevent heat damage.
Old Dec 20, 2007 | 11:51 AM
FUN LS1's Avatar
FUN LS1
St. Jude Donor '08-'09
Best mod for the C5 ever.
Old Dec 20, 2007 | 08:51 PM
Novat_99's Avatar
Novat_99
Good luck...install is done in seconds...once you get under it
Old Dec 20, 2007 | 08:55 PM
Jet-Jock's Avatar
Jet-Jock
If you have a pair of ramps, just back it up on the ramps. Slide in from the back side, 5 minutes or less you've got the job done.
Piece of cake.
Old Dec 20, 2007 | 08:59 PM
Bob CTS's Avatar
Bob CTS
Old Dec 20, 2007 | 09:48 PM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
Pleeeeease.
You guys need automatic Toyota's
Old Dec 20, 2007 | 09:53 PM
love my car's Avatar
love my car
Sorry guys i dont have one.Dont see a need for it.Some guys do some dont,but best mod ever???????? no way....
Old Dec 20, 2007 | 10:18 PM
Ol'55's Avatar
Ol'55
From: Southern New Jersey, The wet part at the bottom
Best $20 I have spent on the car to date. Of course the later "tune" also disabled both the CAGS and the dash light, But it's way more than $20.
Old Dec 20, 2007 | 10:23 PM
CJR2's Avatar
CJR2
St. Jude Donor '08
I've got to do this. It's unbelievable that this was designed to save fuel as I have to rev the engine rpms up before shifting in bumper to bumper traffic to keep the damn thing from engaging! Very stupid.
To CAGS Shift Eliminator
Old Dec 20, 2007 | 10:27 PM
CJR2's Avatar
CJR2
St. Jude Donor '08
Originally Posted by screw991le
Use pucks.
Pucs suck. Get a piece of 3 x 10 ply wood, place on your low profile racing jack (got a great deal on my Harbour Freight jack on-line) and and lift from the rear or front aluminum cross-member. Takes 5 to 7 strokes to raise each end of the car and be sure use jack stands on the cross member for insurance if you are crawling under the car. Changing wheels, not necessary but again safer.
I Autocross so we change our wheel/tires weekly during racing season. Remember...pucs suck, no real vette guy uses them. Sorry!
Old Dec 20, 2007 | 11:54 PM
rws.1's Avatar
rws.1
If you have a set of ramps ...just back up onto them... there will be enough room to getunder and do the install
10 minutes including cracking a cold one afterwards...
Old Dec 21, 2007 | 07:38 AM
SJSZ06's Avatar
SJSZ06
Piece of cake.
That's how I did mine. Took longer than 5 minutes because I had never been on the underside (only had the car about a month) and I had to admire the view!
