[Z06] back up lights not working
Old Dec 19, 2007 | 10:27 PM
LT1driver's Avatar
LT1driver
Default back up lights not working
is there a fuse for the back up lights on the Z? Relay? they don't come on when I put in reverse and they used to before I changed out the battery after car sat for 3 weeks
Old Dec 20, 2007 | 12:48 AM
LT1driver's Avatar
LT1driver
nobody????????????
Old Dec 20, 2007 | 01:25 AM
deicar3's Avatar
deicar3
Default back up lamps
Activate your car alarm on your key fob. If they light up then you know its not your fuse. Now put your key in the ignition and turn on the ignition. Put the car in reverse. If the light does not work it is your sending unit on the right side of your transmission. GM part # 14069600
Easy to install. Five minute job. Hope this helps.
Old Dec 20, 2007 | 11:46 AM
mymaur's Avatar
mymaur
I had the same problem. Disconnect the battery and reconnect it. THis solved my problem. also as mentioned by another member. If your key fob turns them on then the are working. Good luck.
Old Dec 20, 2007 | 02:34 PM
LT1driver's Avatar
LT1driver
thanks guys
To back up lights not working
