Easy question - Frame Rail Color
Old Dec 20, 2007 | 06:16 PM
Bob CTS's Avatar
Bob CTS
Default Easy question - Frame Rail Color
Working on the battery acid clean up and was wondering what the best color to use on the black portion of the frame rail?
Old Dec 20, 2007 | 06:19 PM
hotwheels57's Avatar
hotwheels57
...semi gloss black?
Old Dec 20, 2007 | 06:22 PM
Bob CTS's Avatar
Bob CTS
Thanks. I was not sure if it was a flat or semi-gloss
Old Dec 20, 2007 | 06:24 PM
Ron71's Avatar
Ron71
Krylon make a semi-flat that should be a pretty close match.
Old Dec 20, 2007 | 06:25 PM
hotwheels57
I'm just going by the image...would it really matter? No one else is going to know you've done it. Road grime will soon cover anything you use anyway.
I've always found that semi gloss paint seems to hold up better (and blend better) to the elements than flat black, but it wasn't a scientific study...
Semi flat should work just as well.
Old Dec 20, 2007 | 07:01 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Actually, Eastwwod makes a product called chasis black that is used on the frames and will match up and protect against rust.
http://eastwood.resultspage.com/sear...=chassis+black
Old Dec 20, 2007 | 07:08 PM
vetter79's Avatar
vetter79
Make sure you use a rust- inhibiting primer first!
Old Dec 20, 2007 | 07:15 PM
damilleniumboy's Avatar
damilleniumboy
To Easy question - Frame Rail Color
