AC belt replacement tip
Old Dec 20, 2007 | 11:07 PM
1KLRTOY's Avatar
1KLRTOY
Default AC belt replacement tip
I just replaced both belts and had some trouble instaling the new GY AC belt.Theres not much room to work and with the tensioner all the way I could not get the new one on. Have a helper hold the tensioner from under the car then from above remove the upper idler pully (1-15mm bolt) put the belt on then replace the idler, release the tensioner and your done. On A4's the trans cool lines are right in front of the idler, just seperate them to get the socket on. I hope this helps someone in geting that new AC belt on
