[Z06] dumb question
Old Dec 20, 2007 | 11:33 PM
hellothere's Avatar
hellothere
Default dumb question
today my driver information center said "service Vehicle soon, service traction control." Since i am approaching 45K miles, i assuming its just schedule maintenance. Being 21 and a rookie vette owner, how much is this going to cost?? What are the cost to benefit, in this service?? Just need information and advice in general. THANKS!!!
Old Dec 20, 2007 | 11:39 PM
PeteZ06's Avatar
PeteZ06
St. Jude Donor '07-'08-'09-'10-'11
Has nothing to do with scheduled maintanance.
You either have a faulty computer module or possibly your battery might be a little on the low side. If your battery is just a few volts low during start up, it triggers that message. I had the same issue, then I started keeping my battery on a slow charge every week or two and the problem went away.
Or you can just buy a new battery, but I'm cheap
But its either of those two issues. I'd try the battery first, its cheaper.
Old Dec 21, 2007 | 02:00 AM
striper's Avatar
striper
You have to check your car for codes. Most likely you are having an ABS module fault. I don't remember the whole procedure, I'm sure someone on the forum will be able to help you, but you need to go into the DIC and check the codes. You are probably experiencing C1214. The repair can be as simple as checking electrical grounds or your ABS module needs to be repaired, which unless you have an extended warranty, is too expensive to have your dealership repair. There are aftermarket places that do the work for a fraction of the dealer cost. I was lucky, I just had to clean and tighten a ground connection.
Old Dec 21, 2007 | 04:37 AM
hellothere's Avatar
hellothere
hmm... just replaced the battery 2 months ago...
Old Dec 21, 2007 | 05:40 AM
only59's Avatar
only59
re-check the battery terminal connections. These cars are very sensitive to poor electrical connections.
here's a bit of logic, review the last service that was done to the car, in this instance it was securing the batter terminal connections.
good luck
t
Old Dec 21, 2007 | 08:03 AM
e-hodges's Avatar
e-hodges
St. Jude Donor '06-'09
Default read the FAQ #28 on DIC codes
http://forums.corvetteforum.com/show...2&postcount=28
Old Dec 21, 2007 | 08:34 AM
p_dubya's Avatar
p_dubya
I had that show up one day to and it stayed on the whole drive to work. It was gone at the next startup and I haven't seen it since.
Old Dec 21, 2007 | 08:44 PM
hellothere's Avatar
hellothere
Update - Today, i was expecting the "service vehicle soon" but didnt not see it at all today, just like the previous post.
Old Dec 21, 2007 | 08:55 PM
Bob CTS's Avatar
Bob CTS
Did you check the codes? SHould have one in history.
Old Dec 23, 2007 | 11:18 PM
e-hodges's Avatar
e-hodges
intermittent messages is how mine started too, after a while it will become more and more frequent and then fail.
I replaced the ebcm a few weeks ago....
To dumb question
