Pulling SES codes
Old Dec 22, 2007 | 08:22 PM
AZZ-KIKR's Avatar
AZZ-KIKR
Default Pulling SES codes
I've tried to do a search and can't find the instructions on how to get the codes and the reference list of what they are. I have an intermittent one on the 02 Z, i would just like to see what it is.
I have a feeling that going from Sea-level to 5K ft over night might have something to do with it, but I wan to make sure.
So, if you can point me in that general direction, I would appreciate it.
Thanks!
Old Dec 22, 2007 | 08:28 PM
Bob CTS's Avatar
Bob CTS
Hold in options press fuel four times. It will then automatically display. Hold reset to clear them.
Old Dec 22, 2007 | 08:29 PM
Bob CTS's Avatar
Bob CTS
Code List
10-PCM - Powertrain Control Module
P0101 Mass Air Flow (MAF) System Performance
P0102 Mass Air Flow (MAF) Sensor Circuit Low Frequency
P0103 Mass Air Flow (MAF) Sensor Circuit High Frequency
P0107 Manifold Pressure (MAP) Sensor Circuit Low Voltage
P0108 Manifold Pressure (MAP) Sensor Circuit High Voltage
P0112 Intake Air Temp (IAT) Sensor Circuit Low Voltage
P0113 Intake Air Temp (IAT) Sensor Circuit High Voltage
P0117 Engine Coolant Temp (ECT) Sensor Low Voltage
P0118 Engine Coolant Temp (ECT) Sensor High Voltage
P0118 Engine Coolant Temperature (ECT) Excessive Time to Closed Loop Fuel Control
P0131 Heated Oxygen Sensor (HO2S) Circuit Low Voltage Bank 1 Sensor 1
P0132 Heated Oxygen Sensor (HO2S) Circuit High Voltage Bank 1 Sensor 1
P0133 Heated Oxygen Sensor (HO2S) Slow Response Bank 1 Sensor 1
P0134 Heated Oxygen Sensor (HO2S) Circuit Insufficient Activity Bank 1 Sensor 1
P0135 Heated Oxygen Sensor (HO2S) Heater Circuit Bank 1 Sensor 1
P0137 Heated Oxygen Sensor (HO2S) Circuit Low Voltage Bank 1 Sensor 2
P0138 Heated Oxygen Sensor (HO2S) Circuit High Voltage Bank 1 Sensor 2
P0140 Heated Oxygen Sensor (HO2S) Circuit Insufficient Activity Bank 1 Sensor 2
P0141 Heated Oxygen Sensor (HO2S) Heater Circuit Bank 1 Sensor 2
P0151 Heated Oxygen Sensor (HO2S) Circuit Low Voltage Bank 2 Sensor 1
P0152 Heated Oxygen Sensor (HO2S) Circuit High Voltage Bank 2 Sensor 1
P0153 Heated Oxygen Sensor (HO2S) Slow Response Bank 2 Sensor 1
P0154 Heated Oxygen Sensor (HO2S) Circuit Insufficient Activity Bank 2 Sensor 1
P0155 Heated Oxygen Sensor (HO2S) Heater Circuit Bank 2 Sensor 1
P0157 Heated Oxygen Sensor (HO2S) Circuit Low Voltage Bank 2 Sensor 2
P0158 Heated Oxygen Sensor (HO2S) Circuit High Voltage Bank 2 Sensor 2
P0160 Heated Oxygen Sensor (HO2S) Circuit Insufficient Activity Bank 2 Sensor 2
P0161 Heated Oxygen Sensor (HO2S) Heater Circuit Bank 2 Sensor 2
P0171 Fuel Trim System Lean Bank 1
P0172 Fuel Trim System Rich Bank 1
P0174 Fuel Trim System Lean Bank 2
P0175 Fuel Trim System Rich Bank 2
P0230 Fuel Pump Control Circuit
P0300 Engine Misfire Detected
P0325 Knock Sensor (KS) System
P0327 Knock Sensor (KS) Circuit Front
P0332 Knock Sensor (KS) Circuit Rear
P0335 CKP Sensor Circuit
P0336 CKP Sensor Circuit Performance
P0341 CMP Circuit Performance
P0342 CMP Sensor Circuit Low Voltage
P0343 CMP Sensor Circuit High Voltage
P0351 Ignition Control #1 Circuit
P0352 Ignition Control #2 Circuit
P0353 Ignition Control #3 Circuit
P0354 Ignition Control #4 Circuit
P0355 Ignition Control #5 Circuit
P0356 Ignition Control #6 Circuit
P0357 Ignition Control #7 Circuit
P0358 Ignition Control #8 Circuit
P0410 AIR System
P0412 AIR Solenoid Relay Control Circuit
P0418 AIR Pump Relay Control Circuit
P0420 TWC System Low Efficiency Bank 1
P0430 TWC System Low Efficiency Bank 2
P0441 EVAP System No Flow During Purge
P0461 Fuel Level Sensor 1 Circuit Performance
P0462 Fuel Level Sensor 1 Circuit Low Voltage
P0463 Fuel Level Sensor 1 Circuit High Voltage
P0480 FC Relay 1 Control Circuit
P0481 FC Relay 2 and 3 Control Circuit
P0500 VSS Circuit (M/T)
P0506 Idle Speed Low
P0507 Idle Speed High
P0522 Engine Oil Pressure Sensor Circuit Low Voltage
P0523 Engine Oil Pressure Sensor Circuit High Voltage
P0530 A/C Refrigerant Pressure Sensor Circuit
P0562 System Voltage Low
P0563 System Voltage High
P0567 Cruise Resume Circuit
P0568 Cruise Set Circuit
P0571 Cruise Brake Switch Circuit (M/T)
P0601 PCM Memory
P0602 PCM Not Programmed
P0604 PCM RAM Performance
P0606 PCM Internal Communication Interrupted
P0608 VSS Output Circuit
P0650 MIL Control Circuit
P0654 Engine Speed Output Circuit
P0704 Clutch Switch Circuit (M/T)
P0705 Transmission Range Switch Circuit (A/T)
P0706 Transmission Range Switch Performance (A/T)
P0801 Reverse Inhibit Solenoid Control Circuit (M/T)
P0803 1-4 Upshift Solenoid Control Circuit (M/T)
P0804 1-4 Upshift Lamp Control Circuit (M/T)
P1111 Intake Air Temperature (IAT) Sensor Circuit Intermittent High Voltage
P1112 Intake Air Temperature (IAT) Sensor Circuit Intermittent Low Voltage
P1114 ECT Sensor Circuit Intermittent Low Voltage
P1115 ECT Sensor Circuit Intermittent High Voltage
P1120 TP Sensor 1 Circuit
P1125 APP System
P1133 Heated Oxygen Sensor (HO2S) Insufficient Switching Bank 1 Sensor 1
P1134 Heated Oxygen Sensor (HO2S) Transition Time Ratio Bank 1 Sensor 1
P1153 Heated Oxygen Sensor (HO2S) Insufficient Switching Bank 2 Sensor 1
P1154 Heated Oxygen Sensor (HO2S) Transition Time Ratio Bank 2 Sensor 1
P1220 TP Sensor 2 Circuit
P1221 TP Sensors 1, 2 Performance
P1258 Engine Coolant Over Temperature-Fuel Disabled
P1275 APP Sensor 1 Circuit
P1276 APP Sensor 1 Circuit Performance
P1280 APP Sensor 2 Circuit
P1281 APP Sensor 2 Circuit Performance
P1285 APP Sensor 3 Circuit
P1286 APP Sensor 3 Circuit Performance
P1380 EB (T) CM DTC Detected- Rough Road Data Unusable
P1381 Misfire Detected - No EB (T) CM/PCM Serial Data
P1415 AIR System Bank 1
P1416 AIR System Bank 2
P1431 Fuel Level Sensor 2 Circuit Performance
P1432 Fuel Level Sensor 2 Low Voltage
P1433 Fuel Level Sensor 2 High Voltage
P1441 Evaporative Emissions (EVAP) System Flow During Non-Purge
P1514 TAC System MAF Performance
P1515 Command vs Actual Throttle Position Performance (PCM Module)
P1516 Command vs Actual Throttle Position Performance (TAC Module)
P1517 TAC Module Processor
P1518 PCM to TAC Module Serial Data Circuit
P1539 A/C Clutch Status Circuit High Voltage
P1545 A/C Clutch Relay Control Circuit
P1546 A/C Clutch Status Circuit Low Voltage
P1571 ASR Desired Torque
P1574 Stop Lamp Control Circuit
P1575 Extended Travel Brake Switch Circuit High Voltage
P1626 Theft Deterrent System Fuel Enable Circuit
P1630 Theft Deterrent System PCM In Learn Mode
P1631 Theft Deterrent System Password Incorrect
P1635 5 Volt Reference #1 Circuit
P1639 5 Volt Reference #2 Circuit
P1644 Delivered Torque Output Circuit
P1652 Powertrain Induced Chassis Pitch Output Circuit
28-TCS - Traction Control System
C1214 Sol Valve Relay Contact or Coil CKT Open
C1217 BPMV Pump Motor Relay Contact CKT Open
C1221 LF Wheel Speed Sensor Input Signal is 0
C1222 RF Wheel Speed Sensor Input Signal is 0
C1223 LR Wheel Speed Sensor Input Signal is 0
C1224 RR Wheel Speed Sensor Input Signal is 0
C1225 RF Excessive Wheel Speed Variation
C1226 LF Excessive Wheel Speed Variation
C1227 LR Excessive Wheel Speed Variation
C1228 RR Excessive Wheel Speed Variation
C1232 LF Wheel Speed Circuit Open or Shorted
C1233 RF Wheel Speed Circuit Open or Shorted
C1234 LR Wheel Speed Circuit Open or Shorted
C1235 RR Wheel Speed Circuit Open or Shorted
C1236 Low System Supply Voltage
C1237 High System Supply Voltage
C1241 Magna Steer Circuit Malfunction
C1242 BPMV Pump Motor Ground Circuit Open
C1243 BPMV Pump Motor Stalled
C1255 EBTCM Internal Malfunction
CEBCM Internal Malfunction
C1261 LF Inlet Valve Solenoid Malfunction
C1262 LF Outlet Valve Solenoid Malfunction
C1263 RF Inlet Valve Solenoid Malfunction
C1264 RF Outlet Valve Solenoid Malfunction
C1265 LR Inlet Valve Solenoid Malfunction
C1266 LR Outlet Valve Solenoid Malfunction
C1267 RR Inlet Valve Solenoid Malfunction
C1268 RR Outlet Valve Solenoid Malfunction
C1273 RF TCS Master Cyl Isolation Valve Malfunction
C1274 RF TCS Prime Valve Malfunction
C1276 Delivered Torque Signal CKT Malfunction
C1277 Requested Torque Signal CKT Malfunction
C1278 TCS Temporarily Inhibited By PCM
C1281 Steering Sensor Uncorrelated Malfunction
C1286 Steering Sensor Bias Malfunction
C1287 Steering Sensor Rate Malfunction
C1291 Open Brake Lamp Sw Contacts During Deccel
C1293 DTC C1291/C1292 Set Curnt/Prev Ign Cylce
C1294 Brake Lamp Switch Circuit Always Active
C1295 Brake Lamp Switch Circuit Open
U1016 Loss of Communications with PCM
U1255 Generic Loss Communications
U1300 Class 2 Circuit Shorted to Ground
U1301 Class 2 Circuit Shorted to Battery
38-RTD - Real Time Damping
C1650 ESC Module Malfunction
C1658 EEPROM Calibration Malfunction
C1710 LF Shock Absorber Solenoid (Short to Voltage)
C1711 LF Shock Absorber Solenoid (Short to GND)
C1712 LF Shock Absorber Solenoid (Open Circuit)
C1715 RF Shock Absorber Solenoid (Short to Voltage)
C1716 RF Shock Absorber Solenoid (Short to GND)
C1717 RF Shock Absorber Solenoid (Open Circuit)
C1720 LR Shock Absorber Solenoid (Short to Voltage)
C1721 LR Shock Absorber Solenoid (Short to GND)
C1722 LR Shock Absorber Solenoid (Open Circuit)
C1725 RR Shock Absorber Solenoid (Short to Voltage)
C1726 RR Shock Absorber Solenoid (Short to GND)
C1727 RR Shock Absorber Solenoid (Open Circuit)
C1743 Loss of Vehicle Speed Signal
C1760 LF Position Sensor (Out of Range)
C1761 RF Position Sensor (Out of Range)
C1762 LR Position Sensor (Out of Range)
C1763 RR Position Sensor (Out of Range)
C1768 Position Sensor Supply Malfunction (Overcurrent)
C1780 Loss of Steering Position Signal
C1786 RTD Control Relay Malfunction
C1787 RTD Control Relay Circuit (Open or Short to GND)
C1788 RTD Control Relay Circuit (Short to Voltage)
C1790 Ride Control Switch (Out of Range)
C1791 Ride Control Switch (Contact Malfunction)
40-BCM -Body Control Module
B0432 Rear Defogger Relay Circuit
B0433 Rear Defogger Relay Circuit
B0502 RH DRL Relay Circuit
B0503 RH DRL Relay Circuit
B0507 LH DRL Relay Circuit
B0508 LH DRL Relay Circuit
B0605 BCM Internal Memory Function
B0844 BCM Temporarily Inhibit ABS
B2403 Front Fog Lamp Switch Circuit
B2408 Rear Fog Lamp Switch Circuit
B2482 Backup Lamp Relay Circuit
B2483 Backup Lamp Relay Circuit
B2527 Horn Relay Circuit
B2528 Horn Relay Circuit
B2573 Hatch Release Switch Circuit (Short to Voltage)
B2578 RF Turn Signal Monitor Circuit (Short to Voltage)
B2583 LF Turn Signal Monitor Circuit (Short to Voltage)
B2587 Column Lock/Unlock Drive (A)
B2588 Column Lock/Unlock Drive (A)
B2592 Column Lock/Unlock Drive (B)
B2583 Column Lock/Unlock Drive (B)
B2597 Traction Control System Switch Circuit
B2721 PASS-Key Detection Circuit
B2722 PASS-Key Detection Circuit
B2723 PASS-Key Detection Circuit
B2735 PASS-Key Programming Mode Active
U1096 Loss of Communications with IPC
U1255 Serial Data Line Malfunction
60-IPC - Instrument Panel Cluster
B0516 Speedometer Signal Circuit Malfunction
B0521 Tachometer Signal Circuit Malfunction
B1512 DIC Switch 1 Signal Short to GND "FUEL"
B1517 DIC Switch 2 Signal Short to GND "GAGES"
B1522 DIC Switch 3 Signal Short to GND "TRIP"
B1527 DIC Switch 4 Signal Short to GND "OPTIONS"
B1532 DIC Switch 5 Signal Short to GND "E/M"
B1537 DIC Switch 6 Signal Short to GND "RESET"
B1542 Oil Temperature Circuit Short to GND
B1543 Oil Temperature Circuit Open
U1040 Loss of Communications with TCS
U1056 Loss of Communications with RTD
U1064 Loss of Communications with BCM
U1128 Loss of Communications with Radio
U1153 Loss of Communications with HVAC
U1160 Loss of Communications with LDCM
U1161 Loss of Communications with RDCM
U1166 Loss of Communications with SCM
U1176 Loss of Communications with RFA
80-Radio - Radio Not Found
99-HVAC - Heater, Ventilation, Air Conditioning
B0332 Outside Air Temp Sensor Short to GND
B0333 Outside Air Temp Sensor Open
B0337 Inside Air Temp Sensor Short to GND
B0338 Inside Air Temp Sensor Open
B0348 Sunload Temperature Sensor Open
B0361 Left Actuator Feedback Short to GND
B0363 Left Actuator Feedback Open
B0365 Right Actuator Feedback Short to GND
B0367 Right Actuator Feedback Open
B0441 Left Actuator Out of Range
B0446 Right Actuator Out of Range
B1016 Loss of Communications with PCM
A0-LDCM - Left Door Control Module
B2202 Left Window Up Switch Fault
B2204 Left Window Down Switch Fault
B2206 Right Window Up Switch Fault
B2208 Right Window Down Switch Fault
B2222 LT Mirror Select Switch Fault
B2224 RT Mirror Select Switch Fault
B2226 Mirror Right Switch Fault
B2228 Mirror Left Switch Fault
B2232 Mirror Up Switch Fault
B2234 Mirror Down Switch Fault
B2236 Left Door Lock Switch Fault
B2238 Left Door UnLock Switch Fault
B2242 Memory 1 Switch Fault
B2244 Memory 2 Switch Fault
B2252 Key Cylinder Switch Fault
B2262 Horizontal Position Sensor Fit
B2264 Vertical Position Sensor Fault
B2272 Left Mirror Motor Fault
B2274 Window Motor Fault
B2276 Door Lock Motor/Mirror Heater Fit
B2282 Battery #1 Fault
B2284 Battery #2 Fault
B2286 +5V Reference Fault
A1-RDCM - Right Door Control Module
B2203 Right Window Up Switch Fault
B2205 Right Window Down Switch Fault
B2237 Right Door Lock Switch Fault
B2239 Right Door Un-Lock Switch Fault
B2253 Key Cylinder Switch Fault
B2263 Horizontal Position Sensor Fit
B2265 Horizontal Position Sensor Fault
B2273 Right Mirror Motor Fault
B2275 Window Motor Fault
B2277 Door Lock Motor/Mirror Heater Fit
B2283 Battery #1 Fault
B2285 Battery #2 Fault
B2287 +5V Reference Fault
A6-SCM - Seat Control Module
B0846 Battery 2 Out of Range
B0851 Battery 1 Out of Range
B2002 Fore/Aft Seat Motor Open or Short to GND
B2007 Front Vertical Seat Motor Open or Shorted
B2012 Rear Vertical Seat Motor Open or Shorted
B2172 Seat Front Up Switch Shorted to GND
B2177 Seat Front Down Switch Shorted to GND
B2182 Seat Rear Up Switch Shorted to GND
B2187 Seat Rear Down Switch Shorted to GND
B2192 Seat Forward Switch Shorted to GND
B2197 Seat Reverse Switch Shorted to GND
B2605 Seat Front Vertical Position Sensor Failure
B2606 Seat Rear Vertical Position Sensor Failure
B2607 Seat Horizontal Position Sensor Failure
B0-RFA - Remote Function Actuation
B0605 Receiver Internal Memory Malfunction
B2805 No Transmitters Programmed
C2100 Left Front TPM Sensor Malfunction
C2105 Right Front TPM Sensor Malfunction
C2110 Right Rear TPM Sensor Malfunction
C2115 Left Rear TPM Sensor Malfunction
C2120 TPM System Malfunction (No Sensors Received)
C2121 TPM System Programming Malfunction (No Sensors Programmed)
U1000 Loss of Communication Undetermined
U1016 Loss of Communication with PCM
U1064 Loss of Communication with BCM
U1096 Loss of Communication with IPC
Old Dec 22, 2007 | 08:31 PM
AZZ-KIKR's Avatar
AZZ-KIKR
Perfect, thank you! I could not find them doing a search to save my life.
Old Dec 22, 2007 | 08:38 PM
AZZ-KIKR's Avatar
AZZ-KIKR
Hmm, well I have a P0410 H C ( h- history, correct, and C current?)
Air system. What does that mean to you?
Old Dec 22, 2007 | 08:39 PM
Bob CTS's Avatar
Bob CTS
Not to sure, others will chime in, I would reset it and see if it comes back. You are correct, H=history and C=current
Old Dec 22, 2007 | 08:42 PM
AZZ-KIKR's Avatar
AZZ-KIKR
Thanks, I did a search for the code and read about it. The car has headers, so I'm not sure if that affects this or not. I will have to do some more research.
Old Dec 22, 2007 | 08:52 PM
AZZ-KIKR's Avatar
AZZ-KIKR
Thanks. I wondered if it was something similar to that. I've seen that on other vehicles when I had an EVAP code. I have not put fuel in the car since it arrived, I will check that and go from there.
EDIT: this was a response to another post about it might being the gas cap and is no longer here. hmmm. oh well.
Old Dec 22, 2007 | 08:55 PM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
Sorry pulled the wrong code.
This post by Forum Member Bell about sums it up
P0410 DTC indicates that the secondary air system is not functioning properly. I just fixed this on my 02 Coupe. One of the common causes is a deteriorated vacuum tube which runs underneath the battery. If the battery has leaked at all, this is probably the cause. Take the passenger side front wheel off. Remove the wheelwell panel that's right in front of the battery. You'll find a plastic conduit about 3/8" diameter that will have two wires and 1 black hard plastic vacuum tube (about 1/8" diameter) running inside. The vacuum tube allows suction from the intake manifold to open a valve which is on the discharge side of the secondary air pump. The air pump is located under the driver's side headlight. It sucks clean air from the air filter and pushes it through a hose up the driver's side fender to the area right under the brake master cylinder. There it tees and goes through a check valve in each leg of the tee and puts air into the exhaust headers on startup to dilute the emissions. If the driver's side check valve is blocked, you'll get DTC P1415, if the passenger side is blocked (that check valve is between the back of the engine and the firewall - you can't see it) you'll get P1416. If both are blocked you can get P0410. But the most likely cause is the deteriorated vacuum line under the battery. You can quickly and easily check that and fix it.
I'd start at the manifold and go backwards. Usually it is the line at the manifild that is weak becasue of all the heat...
Peace
Chip
__________________
..................Click for
Old Dec 22, 2007 | 09:02 PM
Bill Dearborn's Avatar
Bill Dearborn
Here is the diagnostic info you need the above list is incrementally better than useless. The bottom part of the diagnostic is a table but it doesn't display as a table on the forum.
Bill
DTC P0410
Circuit Description
A secondary air injection (AIR) pump is used on this vehicle in order to lower the tail pipe emissions during start-up. The powertrain control module (PCM) supplies a ground to the AIR pump relay, which energizes the AIR pump.
The PCM monitors the heated oxygen sensor (HO2S) voltages in order to diagnose the AIR system.
During the AIR test, the PCM activates the AIR pump during closed loop operation. When the AIR is activated, the PCM monitors the HO2S voltages, and monitors the short-term fuel trim values for both banks of the engine. If the AIR system is operating correctly, the HO2S voltages should be low, and the short-term fuel trim should be high.
If the PCM determines that the HO2S voltages for both banks did not respond with the expected results during the tests, DTC P0410 sets. If only 1 sensor responded, the PCM sets either DTC P1415 or DTC P1416. The active DTC indicates which bank has the inoperative AIR system.
Conditions for Running the DTC
o DTCs P0101-P0103, P0107, P0108, P0112, P0113, P0116, P0117, P0118, P0125, P0171-P0175, P0200, P0300, P0335, P0336, P0351-P0358, P0440, P0442, P0443, P0446, P0449, P1120, P1220, P1221, P1258, or P1441 are not set.
o The fuel level is more than 12.5 percent but less than 87.5 percent.
o The engine is running for more than 30 seconds.
o The maximum air flow is 22 g/s.
o The air fuel ratio is 13.125:1.
o The engine load is less than 40 percent.
o The ignition voltage is more than 11.7 volts.
o Vehicle speed is more than 15 km/h (25 mph).
o The engine is not operating in any of the following modes:
o Power enrichment
o Decel fuel cut-off mode
o The catalyst over temperature
o The engine is operating in a closed loop for more than 15 seconds.
o The engine speed is more than 850 RPM.
o The engine coolant temperature (ECT) is between than -10°C to +110°C (14°F-230°F).
o The intake air temperature (IAT) is between -10°C to +100°C (14°F-212°F).
o The fuel system is operating in fuel trim cells 1, 2, 4, 5, or 6.
Conditions for Setting the DTC
If the AIR pump turns ON during a closed loop operation and the HO2S voltage does not fall below 222 mV for 1.3 seconds.
Or
If the AIR pump turns ON during a closed loop operation and the short-term fuel trim does not change more than a predetermined amount.
Action Taken When the DTC Sets
o The control module illuminates the malfunction indicator lamp (MIL) on the second consecutive ignition cycle that the diagnostic runs and fails.
o The control module records the operating conditions at the time the diagnostic fails. The first time the diagnostic fails, the control module stores this information in the Failure Records. If the diagnostic reports a failure on the second consecutive ignition cycle, the control module records the operating conditions at the time of the failure. The control module writes the operating conditions to the Freeze Frame and updates the Failure Records.
Conditions for Clearing the MIL/DTC
o The control module turns OFF the malfunction indicator lamp (MIL) after 3 consecutive ignition cycles that the diagnostic runs and does not fail.
o A current DTC, Last Test Failed, clears when the diagnostic runs and passes.
o A history DTC clears after 40 consecutive warm-up cycles, if no failures are reported by this or any other emission related diagnostic.
o Clear the MIL and the DTC with a scan tool.
Diagnostic Aids
Important
o Before you service the PCM or the throttle actuator control (TAC), remove any debris from the module connector surfaces, and from the module connector gaskets. Verify that the gaskets are correctly installed. The gaskets prevent debris from contaminating the modules.
o For any test that requires probing the PCM or probing a component harness connector, use the Connector Test Adapter Kit J 35616-A . Using this kit prevents damage to the component terminals and to the harness. Refer to Using Connector Test Adapters in Wiring Systems.
AIR Pump Relay Underhood Electrical Center Terminal Identification
Front of Vehicle
Left Side of Vehicle Ignition B+ Right Side of Vehicle
Pump Supply Control
o For an intermittent condition, refer to Intermittent Conditions .
o An intermittent may be caused by any of the following conditions:
o Low system air flow may cause this DTC to set.
o Excessive exhaust system back pressure
o Moisture, water or debris ingested into the AIR pump
o Pinched, kinked, heat damaged, or deteriorated hoses or vacuum lines
o Restrictions in the pump inlet, duct, or filter
o An AIR pump that has become inoperative and shows signs of exhaust gases in the outlet port would indicate a check valve failure.
o Thoroughly check any circuitry that is suspected of causing the intermittent complaint. Refer to Testing for Intermittent and Poor Connections .
o If a repair is necessary, refer to Wiring Repairs or Connector Repairs .
Test Description
The numbers below refer to the step numbers on the diagnostic table.
3. If DTCs P0412 or P0418 are set, diagnose those DTCs first.
4. Inspects for excess resistance in all of the circuits that are associated with the AIR system.
5. This step tests for the battery voltage at the AIR pump relay.
6. This step tests for power to the AIR pump.
7. This step tests the ground circuit for the AIR pump.
12. This step tests for a grounded circuit between the AIR pump and the AIR pump relay.
22. A restriction in a hose or in a pipe, between the shut-off valve and the point where the system branches to each bank, causes the setting of this DTC . Inspect for kinks or for blockages from the AIR pump to the connection point where the AIR system divides.
Step Action Yes No
Schematic Reference: Engine Controls Schematics
1 Did you perform the Diagnostic System Check-Engine Controls? Go to Step 2
Go to Diagnostic System Check - Engine Controls
2 Is the AIR pump fuse or the ENG IGN 1 fuse OK? Go to Step 3
Go to Step 11
3
Is DTC P0412 or P0418 active? Go to Diagnostic Trouble Code (DTC) List
Go to Step 4
4
1. Turn ON the ignition, with the engine OFF.
2. Command the AIR pump relay on with the scan tool.
Does the AIR pump turn ON? Go to Step 8
Go to Step 5
5
1. Turn OFF the ignition.
2. Remove the AIR pump relay.
3. Test the B+ supply circuit of the AIR pump relay coil for an open using a test lamp connected to ground. Refer to Diagnostic Aids for terminal identification.
Does the test lamp illuminate? Go to Step 6
Go to Step 16
6
1. Install the AIR pump relay.
2. Disconnect the AIR pump electrical connector. Refer to Secondary Air Injection (AIR) Pump Replacement .
3. Connect a test lamp to battery ground.
4. Probe terminal A of the AIR pump electrical connector. Refer to Probing Electrical Connectors in Wiring Systems.
5. Turn ON the ignition, with the engine OFF.
6. Command the AIR system ON with a scan tool.
Does the test lamp illuminate? Go to Step 7
Go to Step 17
7
Test the ground circuit of the AIR pump for an open or poor ground connection using a test lamp connected to B+ and probing the B terminal of the AIR pump electrical.
Is the test lamp illuminated? Go to Step 27
Go to Step 18
8
2. Disconnect the AIR pump outlet hose from the AIR pump.
3. Turn ON the ignition, with the engine OFF.
4. Command the AIR system ON with a scan tool.
Is air flow present at the AIR pump outlet? Go to Step 9
Go to Step 10
9
2. Disconnect the vacuum hose from the AIR shut off valve.
3. Start the engine.
4. Command the AIR solenoid ON with a scan tool.
Is a vacuum present at the AIR shut-off valve? Go to Step 14
Go to Step 19
10
1. Inspect for a restriction or for a blockage in the AIR Pump inlet hoses and in the AIR Pump inlet pipes.
2. If you find a restriction or a blockage in the AIR hoses and in the pipes, repair the restriction as necessary.
Did you find and correct the condition? Go to Step 29
Go to Step 28
11
3. Connect a test lamp to B+.
4. Test the B+ supply to the AIR pump and the AIR pump relay coil at the relay connector for a short to ground using a test lamp. Refer to Probing Electrical Connectors .
5. Refer to Diagnostic Aids for connector terminal identification.
Does the test lamp illuminate? Go to Step 23
Go to Step 12
12
1. Disconnect the AIR pump electrical connector.
2. Connect a test lamp to B+.
3. Test the AIR pump connector terminal A with a test lamp for a short to ground.
Does the test lamp illuminate? Go to Step 24
Go to Step 13
13
1. Install the AIR pump electrical connector.
2. Install a new AIR pump fuse.
3. Install the AIR pump relay.
4. Turn ON the ignition, with the engine OFF.
5. Command the AIR system ON with a scan tool.
Does the AIR pump fuse open? Go to Step 28
Go to Diagnostic Aids
14
1. Install the following components:
o The AIR pump outlet hose to the AIR pump
o The vacuum hose to the AIR shut-off valve
2. Disconnect the outlet hose of the AIR shut-off valve.
3. Start and idle the engine.
4. Command the AIR system with a scan tool.
Is air present at the outlet of the AIR shut-off valve? Go to Step 22
Go to Step 15
15 Replace the AIR shut-off valve. Refer to Secondary Air Injection (AIR) Shut-Off Valve Replacement .
Did you complete the action? Go to Step 29
16 Repair the open in the B+ supply circuit to the AIR pump relay connector. Refer to Wiring Repairs in Wiring Systems.
17 Repair the open in the AIR pump load circuit between the AIR pump relay and the AIR pump connector. Refer to Wiring Repairs in Wiring Systems.
Go to Step 25
18 Repair the poor ground connection or the open ground circuit of the AIR pump. Refer to Wiring Repairs in Wiring Systems.
Did you complete the repair? Go to Step 29
19
2. Disconnect the source vacuum hose from the AIR Solenoid Valve. Refer to Secondary Air Injection (AIR) Vacuum Control Solenoid Valve Replacement .
Is a vacuum present at the AIR solenoid valve? Go to Step 20
Go to Step 21
20
2. Connect the source vacuum hose to the AIR solenoid valve.
3. Disconnect the vacuum hose to the AIR shut-off valve at the AIR solenoid valve.
4. Start and idle the engine.
5. Command the AIR solenoid valve ON with a scan tool.
Is a vacuum present at the AIR Solenoid Valve outlet? Go to Step 21
Go to Step 26
21 Repair the restriction, the blockage, or the damage to the vacuum hose.
22
Repair the conditions in the AIR hose between the AIR shut-off valve and the point where the system branches to both sides of the engine.
23 Repair the short to ground in the ignition positive voltage circuit between the fuse and the relay. Refer to Wiring Repairs in Wiring Systems.
24 Repair the short to ground in the circuit between the AIR pump relay and the AIR pump. Refer to Wiring Repairs in Wiring Systems.
25 Replace the AIR pump relay.
Did you complete the replacement? Go to Step 29
26 Replace the AIR Solenoid Valve. Refer to Secondary Air Injection (AIR) Vacuum Control Solenoid Valve Replacement .
Did you complete the replacement? Go to s Step 29
27 1. Inspect for poor connections at the AIR pump electrical connector. Refer to Testing for Intermittent and Poor Connections in Wiring Systems.
2. If you find a poor connection, repair the terminal as necessary. Refer to Repairing Connector Terminals in Wiring Systems.
Go to Step 28
28 Replace the AIR pump. Refer to Secondary Air Injection (AIR) Pump Replacement .
29
1. Clear the DTCs with a scan tool.
2. Turn OFF the ignition for 30 seconds.
4. Operate the vehicle within the Conditions for Running the DTC as specified in the supporting text.
Does the DTC run, and pass? Go to Step 30
Go to Step 2
30 Use a scan tool in order to observe the stored information in Capture Info.
Does the scan tool display any DTCs that you have not diagnosed? Go to Diagnostic Trouble Code (DTC) List
System OK
Old Dec 22, 2007 | 09:11 PM
AZZ-KIKR's Avatar
AZZ-KIKR
Thanks for the help guys. I will have to start digging into this. I assume this will not have any negative effects at this time to the engine, etc?
Old Dec 22, 2007 | 09:58 PM
Bob CTS's Avatar
Bob CTS
Sure is not useless to me since it gives an individual where to start as opposed to guessing. OP was wanting a reference list of codes and that is what I posted.
Great post on how to fix it.
Old Feb 8, 2008 | 07:51 PM
HJZ06's Avatar
HJZ06
Drove back from club meeting last night and had no cruise control. No codes displayed so I found this post and my service manual. Checked fuse and then manual stated if low voltage, will not work. I cleared codes and works great! Thanks for the info. Was really worried about taking it to a dealer and the mess after.
To Pulling SES codes
