[Z06] Minor Bolt-On Performance Mods?
Anyways, I was wondering what low-drama, moderate-price mods I could do next. Bear in mind that I am not building a max-effort car...I have my 600+rwhp Z28 for that.
Here's what I'm thinking, so any advice will be appreciated:
Light-weight Oddesey (or similar) battery.
Short-throw shifter or at least shorter stick.
ASP crank pulley.
I will do headers eventually and will probably suck it up and pay for an install along with a tune. Any input or better mod suggestions would be greatly apprecited. Thanks!
Air Intake
Headers
Simple, easy to install, good performance boost, great sound difference, brand doesn't really matter (in the case of the LT's: Kooks, ARH, LG, Dynatech, etc., etc.)
Cam
Springs
Pulley
Note that Y-body cars are a bitch to swap the cam (unlike your F-body) so I'd recommend not doing a pulley swap unless you're also doing a cam swap (the steering rack has to be removed).
Heads
Clutch
Potentially before this level you might need a clutch, but of it's a street car, with a few (road) track events a year, I don't think the mods previous to this will require one (YMMV
) Depending on your head choice, they might be a reusable item for a bigger CI setup.***
90mm Intake Man
90mm Throttle Body
These are moderate bang-for-the-buck, but at this point, it's about the last thing you can do before you go either FI or larger CI. These are great reuse items for bigger CI motors!
I want to do the headers/FAST 90/tune at the same time, so I'm looking for any smaller mods that will ake the car more enjoyable along the way.
As for the rear, aren't they about $2000? How do you get traction, drag-radials?
I'm looking at small mods that I can do between deployments and hen do the big stuff in one lump when I get back to the USA in 2009.
I really appreciate you taking the time to respond!
I promised myself and my wife I wouldn't mod the Z06 after the Z28 situation, but what can I say? I lied.
FYI to the OP, there's a 2-piece cam cover made by a couple of vendors that greatly simpifies changing the cam the 2nd time around (should you want bigger/smaller/FI spec/etc).
If I did a cam, it would be a fairly mild one. I'd be thrilled with 400rwhp from the Z06 with stockish driveability.
Maybe I should just go with a blower and be done with it... I just hate to ADD weight to such a svelte car.
Here's an idle vid of my setup http://www.youtube.com/watch?v=0M-BRVvG8xs
Kirban shifter (much better then stock)
Odyssey battery with bracket from Accurate Technologies, Inc. (http://performance.accuratetechnologies.com/ (20 lbs. lighter then stock and no chance of leaking and ruining ECU)
Sparco Pro 2000 seat (much lighter then stock and actually fits me: 5'10" 150 lbs.) Also purchased from Accurate Technologies because they modify the OEM GM seat rail to maintain fore and aft seat function.
Goodridge braided stainless steel brake lines
DeWitts radiator (replaces cheap plastic end-tanks that can crack with a solid aluminum radiator that also holds a gallon of additional coolant)
HTH,
- Max
HTH,
- Max
I'm pretty much sold on a smaller battery, either the Odyssey or this one: http://www.brailleauto.com/ProductCa...=2&idproduct=1
Do you have a weight comparison guesstimate between the Sparco and stock seats? I'm a pretty wide guy (5'7" 200ish lbs gym rat), but dunno if that's an issue.
Lighter brakes and wheels are down the road a bit, but the lines sound like a great idea.
Never thought about the radiator, thanks!
Have a great holiday!
Regarding seats, you'll just have to sit in them and see. Thankfully, OG Racing in Sterling, VA (not too far from you) is a stocking dealer for Sparco and has them all on the showroom so you can test fit: http://www.ogracing.com/
HTH,
- Max
- Max
Thanks for taking the time to post!
- Max
