LS2 heads
Old Dec 26, 2007 | 05:47 PM
Jack67Marion's Avatar
Jack67Marion
Cruising
Default LS2 heads
Does anone know if the LS2 heads will fit an LS1 engine and if so would there be much of an increase in performance?
Thanks,
Jack
Old Dec 27, 2007 | 12:18 AM
vincentjames501's Avatar
vincentjames501
I think they are the same casting as the ls6 heads and they should bolt right up. Maybe 15RWHP or so??
LS2 heads will give you a different compression ratio as they are made for a larger CUIN block...
LS6 heads will not affect compression ratios as they are make for 346 CUIN...
with that said that is the major difference in putting LS2 heads on a LS1...
Old Dec 27, 2007 | 12:25 AM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
243 (LS6/LS2) heads slightly raise the compression on LS1s due to the smaller 64.4cc chamber size. (the LS1 heads have a 66.7cc chamber)
Has nothing to do with engine CI as posted above.
To LS2 heads
