Leaking rack and pinion assembly
Old Dec 28, 2007 | 10:13 AM
PB FT's Avatar
PB FT
Default Leaking rack and pinion assembly
I have a leaking rack and pinion assembly on my c5 confirmed by dye analysis. The dealership will repair with new parts and labor for $1600. A local corvette specialty shop will do a rebuilt assembly for $650.
What would c5 general do?
Me working on the car is not an option
TIA
Old Dec 28, 2007 | 10:32 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
TIA
A rebuilt unit will work just fine. GM repair is only good for 12 months anyway.
Old Dec 28, 2007 | 12:25 PM
PB FT's Avatar
PB FT
Thanks for the info. The dealership called back, and the service writer said that he "went to bat for me" and was able to get the price knocked down to $1442. The assembly is priced at $562 on gm parts direct. The dealership had the part priced at $1100.
Old Dec 28, 2007 | 12:34 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
You see if some local vette shop could install a new one for you. Should be about (3) hours labor and alignment. Maybe some of your local members would help you out, never hurts to ask.
Old Dec 28, 2007 | 12:44 PM
Beardown3's Avatar
Beardown3
Default I just had it done on my C5
dealer wanted 1500. Remeber thats not including the four wheel alignment you will also need. price of remufactured assembly is about what you said, 1100 was quoted to me for remanufactured unit by dealer.
I had it done at Corvete Mikes for 850
Old Dec 28, 2007 | 01:02 PM
PB FT's Avatar
PB FT
I guess the numbers that I was given are in the ballpark then. I am leaning to the local corvette garage.
This additional repair is just a little bitter pill to swallow since the car just had the high pressure power steering hose replaced. It would have been nice if they would have caught the other (original??) problem at the same time.
Old Dec 28, 2007 | 03:28 PM
bobc997615's Avatar
bobc997615
I'd add the small bottle of Lucas Power Steering Fluid additive just to see if the leak would stop. What's another $10?
Old Dec 28, 2007 | 03:37 PM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
Where is it leaking? FYI there are no brand new C5 racks available... they're all rebuilds.
Old Dec 28, 2007 | 07:53 PM
PB FT's Avatar
PB FT
The leak is at the stub shaft.
Old Dec 28, 2007 | 07:57 PM
Bob CTS's Avatar
Bob CTS
good to know
Old Dec 28, 2007 | 08:01 PM
10U 99's Avatar
10U 99
can't hurt
Old Dec 28, 2007 | 08:04 PM
AzMotorhead's Avatar
AzMotorhead
Limping across the line
Are you flippin kidding me I pulled the rack for a customer (98 Coupe) had the unit rebuilt then reinstalled the same rack + Rebuilt the PS pump and the bill was less than $1400. A experienced mechanic can have the rack out in less than 1 hour.
Find a local front end shop
Old Dec 28, 2007 | 08:33 PM
PB FT's Avatar
PB FT
I may consider this. The leak is now faster after replacing the high pressure hose. Before, it would be a month for the pump to go dry, after the repair, it only took a week. I guess that I don't know how much fluid they put in and they definately did not use anything with stop leak.
Old Dec 28, 2007 | 08:38 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
Go with the CORVETTE specialists, the dealership is just ripping you off (as always).
Old Dec 29, 2007 | 01:31 AM
Choreo's Avatar
Choreo
I had my Harmonic Balancer replaced under GMPP Extended Warranty on my 2001 last May. They had to drop the Steering Rack at that time to get access to it. Of course something was not done correctly when the Steering Rack was re-installed. The car just did not "feel" as tight in the steering as before (and the pinch bolt was not torqued properly either, but I remedied that myself), but I also knew they would not be able to feel the difference since it was slight. A few weeks later I noticed that I was getting a drop of hydraulic fluid on the floor overnight - every night.
When I had my car in the dealership again this month, I mentioned the leak. At first they could find nothing wrong and then finally said the entire steering rack would have to be replaced due to leaking. Therefore, they replaced it under my GMPP, but the replacement rack says AC DELCO REMANUFACTURED PART.
Old Dec 29, 2007 | 06:32 AM
flynloz's Avatar
flynloz
3rd Gear
Lucas stop leak can do wonders. Give it a try first. I had a ford tauras with a rack leak and put some lucas in it . 3 years later when i got rid of it it still didn't leak.
To Leaking rack and pinion assembly
