Turn Signal Socket Grease...?
Old Dec 28, 2007 | 04:19 PM
cletus's Avatar
cletus
Default Turn Signal Socket Grease...?
This week my front pass turn signal stopped working during a drive in hard rain and I got the hyper blinking symptom. Found the fix here but found that the turn signal socket was full of grease and after I wiped a little off, the bulb worked fine. Not blown. I assume the grease was a non-conducting sort to help keep out moisture, but it seemed to short the bulb out. Does GM add the grease?
Any thoughts?
Maybe the bulb was just loose?
Thanks.
Old Dec 28, 2007 | 04:31 PM
10U 99's Avatar
10U 99
St. Jude Donor '08-'09
yep
none
could be
you are welcome
