2001 Z06 ABS problem
Old Dec 29, 2007 | 12:17 PM
NVR_L8's Avatar
NVR_L8
Default 2001 Z06 ABS problem
I have a 2001 Z06 and I get a Service ABS, Service Traction Control, and Service Active Handling on the DIC when starting. Any idea what to check first.
Old Dec 29, 2007 | 10:08 PM
Whiteonrice's Avatar
Whiteonrice
Pull the codes and see what the problem is. Mine has done that a couple of times. Turned it off, pulled the key, let it sit a minute or two and everything was OK. If that doesn't work disconnect the battery for awhile. If this doesn't work you might have more serious problems. Good luck hope it isn't serious.
Rick
Old Dec 29, 2007 | 10:14 PM
Bob CTS's Avatar
Bob CTS
Pull the codes and let us know what they are. Hold options and press fuel four times with key on run but not with the engine running.
To 2001 Z06 ABS problem
