Rolled While Parked In Gear
Old Dec 30, 2007 | 05:46 AM
peter pan's Avatar
peter pan
Life Time NCM #2196
Originally Posted by Junkman2008
With what little I know about cars, I have taken my back rotors off and have seen the parking brake. There's no way the ebrake can warp your rotors if your brake system is like mine on my 2001 coupe. Like NJ02Vette stated, its more like drum brakes and does not apply any pressure to the part of the rotor that the actual brakes do. Check out this shot from the Helms manual:
As you can see by the picture, the surface area that the ebrake shoes rub up against is totally different from where the regular brake pads rub against.
Good picture and that is how they are on all models and I use my parking brake when ever on an incline
Old Dec 30, 2007 | 06:38 AM
jdmvette's Avatar
jdmvette
Night Owl for life
Originally Posted by RainJ
Had always parked mine in 1st.. Parking brake has not worked since I bought the car.
fix it!
just pull off the rear rotors and adjust the little star nut so the shoes expand.
it's really not hard to do. and since i've done mine myself, i'm very confident that my parking brakes won't fail on me.
Old Dec 30, 2007 | 06:46 AM
jacks996's Avatar
jacks996
Jacks996
Cruise-In VIII Veteran
I always use the brake even on flat ground.
Old Dec 30, 2007 | 07:51 AM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
When you park your car in gear you are relying on the compression of the engine and the resistance of the transmission to hold it in place. You really should always use a parking brake as an added measure. You will not warp your rotor. The parking brake system uses brake pads pressing against the inside of the "hat" of the rotor as pictured below (photo credit to Patches)
Old Dec 30, 2007 | 07:55 AM
Jeff_in_Atl's Avatar
Jeff_in_Atl
Here is what you should remember, for a manual transmission car always put it in the lowest gear in the direction it will want to roll. If you park it facing down hill you put it in first. If you park it up hill you put it in reverse. The reason it rolled was because it never built compression because the engine rotated backwards. It is really bad on an engine to rotate backwards. The bearings get used to the crank and cam rotating one way. When it is rotated the other way it can sometimes roll a bur and gouge the bearings. Also the oil pump will suck the oil out of the lifters. Then when you crank it they will float the valves until they pump back up. If you rev it before they pump up the piston can hit a valve. Oh and as it says above you will not warp a rotor if you use the emergency brake so use it whenever you park on any slope.
Old Dec 30, 2007 | 08:35 AM
mitch1959's Avatar
mitch1959
I always use my parking brake (auto) even on flat surfaces a lot of people laugh but if you brake the parking pawl it will set you back $$$$.$$. don't ask me how I know!!
Old Dec 30, 2007 | 08:51 AM
OzzyC4's Avatar
OzzyC4
Maybe I am more **** or stupid than most.
My dad taught me to always engage the parking brake BEFORE putting the auto trans in park when parking on anything other than level.
His thought is that way the brake is holding the load and not the pawl.
I do know that by doing it his way I have never experienced the pull the Shift lever hard and hear a bang when taking it out of park like I have when with friends.
Old Dec 30, 2007 | 10:48 AM
87SAM's Avatar
87SAM
Yep, from the manual:
Torque Lock (Automatic Transmission)
If you are parking on a hill and you don’t shift your
transmission into PARK (P) properly, the weight of the
vehicle may put too much force on the parking pawl in
the transmission. You may find it difficult to pull the
shift lever out of PARK (P). This is called “torque lock.”
To prevent torque lock, set the parking brake and then
shift into PARK (P) properly before you leave the
driver’s seat. To find out how, see “Shifting Into
PARK (P)” in the Index.
When you are ready to drive, move the shift lever out
of PARK (P) before you release the parking brake.
If torque lock does occur, you may need to have another
vehicle push yours a little uphill to take some of the
pressure from the parking pawl in the transmission,
so you can pull the shift lever out of PARK (P).
Parking Your Vehicle
(Manual Transmission)
Before you get out of your vehicle, put your manual
transmission in REVERSE (R) and firmly apply the
parking brake.
Old Dec 30, 2007 | 10:57 AM
Junkman2008's Avatar
Junkman2008
parking brake.
Wow, good info! I had never heard of a "pawl" before...
Old Dec 30, 2007 | 11:06 AM
Jeff_in_Atl
parking brake.
While that may work most of the time it will not work all of the time. Been there done that. My car rolled about 100 feet down a steep driveway out in the middle of Houston Mill road near Emory. Luckily it was about 2 am in the morning when it happened. I didn't know it until a car honked their horn and I looked out the window. It took about 5 minutes for the lifters to quit making noise. My post above is the correct way to park a manual car.
Old Dec 30, 2007 | 11:21 AM
basicstrategy777's Avatar
basicstrategy777
St. Jude Donor '11-'12-'13-'14-'15-'16-'17,'20, '21,'22, '23
I read someplace you can adjust your parking brake if you roll backwards down a long hill; don't remember if it manual gearshift should be in neutral or in reverse.
777
Old Dec 30, 2007 | 11:29 AM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Originally Posted by 2k2C5
I believe the parking brake is a small drum brake on one side and has no effect on the rotor as the caliper is not used.
Parking brake doesn't use the caliper on the wheels. There is a small drum brake for this purpose. If it is not effective, and many of them are way out of adjustment....adjust it!
http://forums.corvetteforum.com/show...6&postcount=17
Old Dec 30, 2007 | 11:47 AM
  #33
mark man's Avatar
mark man
A year or 2 ago I was parked on small incline. Another Vette 4 feet behind me.
We walked around 20 minutes and returned to find my Vette resting against the front bumper of 2nd Vette!
Still strongly in 1st gear.
Thats when I read that you are supposed to park it in Reverse.
Stopped at a relative's house to leave the Vette overnight while we drove on up in the SUV with the familiy for a holiday.
While I was sitting in the Vette, engine off, 1st Gear, VERY STEEP driveway incline, I noticed the Vette inching back. Almost like teeth on a flywheel.. 1 tooth at a time.. click, click, click, click...
Placed it in Reverse and it stopped. (of course being gone overnight, I lowered it to the base of the driveway and parked there - level)
My parking brake did not work either easy to adjust. Small shoes not disc inside rear rotors with star adjusters just like old drum brakes had.
Mine works great now. In reverse with parking brake on.
Old Dec 30, 2007 | 11:55 AM
  #34
vettesmith02's Avatar
vettesmith02
You were lucky!
Old Dec 30, 2007 | 03:30 PM
  #35
CE2004's Avatar
CE2004
http://en.wikipedia.org/wiki/Parking_pawl
Gotta love the Wiki...
