Lowering problem....
Old Dec 30, 2007 | 03:46 AM
Gohard777's Avatar
Gohard777
Default Lowering problem....
I just went out in the garage a couple of days ago and installed longer rear bolts, after measuring, I adjusted to exactly 1 inch longer. I went to the front and found out that I could turn the adjusting screw 5 complete turns before bottoming out. Does anybody have an idea how far this will lower the front? Since the back is 1 inch difference, the 5 turns wasn't an inch so I am worried about the ratio from front to back. I believe that I will be fine but won't be able to drive the car until Spring. Thanks guys for all input and while you're at it, how do you cut the bushings in half on the front. Is there a way to take the things out without disassemblying the front end? Or do you do it on the car?
I posted on tech also, but like this one better....
Thanks..bob.
Old Dec 30, 2007 | 04:34 AM
jdmvette's Avatar
jdmvette
Night Owl for life
yeah most likely your rear will have a smaller gap than your front. if you look at the pics that most guys post, this is often what you will see.
i cut 1/3 of my front bushing off and put longer bolts in the rear. my tires are exceptionally tall in the back so my rear has a smaller gap than the front. i don't want to cut my front bushings any more so the next front tires i get are going to be slightly taller.
Old Dec 30, 2007 | 04:05 PM
Gohard777's Avatar
Gohard777
Could you explain how you cut the front bushings, how do you get them off the car or is it possible to do this on the car?? Thanks.......bob
Old Dec 31, 2007 | 01:52 AM
Gohard777's Avatar
Gohard777
Thanks, was wondering how to cut the front bushings on the car if I'm not satisfied with the other results...bob.
Old Dec 31, 2007 | 05:51 AM
Quik Z06's Avatar
0Quik Z06
Former Vendor
If I remember correcly you can jack up the front end of the car and should be able to get a knife in there and cut it while on the car. Once you get the car in the air it should be obvious if you can or not. Sorry been a while since I lowered the car.
To Lowering problem....
