What sizes do tires start rubbin?
Old Jan 2, 2008 | 08:57 AM
kwhiteside's Avatar
kwhiteside
Default What sizes do tires start rubbin?
I'm debating what size to get for my C5.
I've seen nice 18/19 setups where 275/35/18 front and 305/30/19 rear look pretty good. But do they rub.
I've seen even nicer filling 19/20 setups but haven't been able to gather the best sizes for these.
When do they start rubbing or throwing codes??
Old Jan 2, 2008 | 11:14 AM
jon c's Avatar
jon c
I have the 18/19 setup you mentioned have never rubbed, the important thing is to make sure you have the correct offset on your wheels, I went with the CCW SP20A's. the people at CCW really know their stuff, but once again just make sure the offset is right and you will have no issues..
Old Jan 2, 2008 | 01:22 PM
lionelc5's Avatar
lionelc5
If your going to go any bigger than 18s , remember no one makes a drag radial bigger than 18", at least not yet. Thats why i stayed 18s on mine
Old Jan 2, 2008 | 02:18 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Drag radials are not really stable over a 100 mph, so I don't know why anyone would run them on the street as their daily tire.
Only advantage of 18's is more selection and cheaper pricing.
Old Jan 2, 2008 | 03:38 PM
vincentjames501's Avatar
vincentjames501
Smaller rims act like lower gears would. Another alternative to not having to install gears
Old Jan 2, 2008 | 03:51 PM
Drewstein's Avatar
Drewstein
I ran the BFG DRs up to 200mph so I would say that's stable. I chose them over regular street tires because 800rwhp will break lose 295 F1 Supercars at over 100mph. Which one sounds safer?
Hoosier makes a 19" DoT legal slick type tire. It's more for road racing but many high hp guys run them on their 19s as a DR substitute with good success.
Old Jan 2, 2008 | 03:59 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
A lot of wheel spin can be controlled by pedal modulation. I run a six speed so I have a little better control than the auto with a high stall.
I really don't advocate the F1's or any runflats because they are too stiff. I run Michelin PS2's.
I'm sure at the HP levels you are producing you could spin your tires with relative ease. I pulled my maggie and I am now back to NA for now.
I am not a drag guy so it's not a big deal to me, as I am more interested in handling and top speed. Hopefully some of the aerodynamic mods that I have made will help with traction.
Old Jan 2, 2008 | 04:36 PM
chazzvette's Avatar
chazzvette
305/30/19 on rear...no rubbing. I am going to lower it though, on stock bolts about 1" From what I hear, there still will be no rubbing.
Old Jan 2, 2008 | 05:58 PM
Bill Vett's Avatar
Bill Vett
305/30/19's lowered on stock bolts and no rub. I was going to go with 315's but was told there could be a slight rub on the inside.
Old Jan 2, 2008 | 08:35 PM
jdmvette's Avatar
jdmvette
Night Owl for life
it mostly depends on your offset.
if your wheels are sticking out past the fenders, of course they won't rub.
Old Jan 3, 2008 | 02:23 AM
Sportsdude's Avatar
Sportsdude
19/20 (20/305) setup on mine lowered car without any rubbing.
Old Jan 3, 2008 | 11:13 AM
Wah's Avatar
Wah
I have 315/30/18s on all four. None of the tires rub. It's the front wheels that rub the upper control arms at full turns only.
Old Jan 3, 2008 | 02:17 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
You got any pictures ? and do they stick out of the wheel wells ?
Old Jan 3, 2008 | 02:28 PM
IM28702's Avatar
IM28702
I've got 315/30/18's on the rear with no rubbing, but never imagined that they would fit the front... Huh... Guess who's gonna go test fit his rear wheels on the front this evening?
Old Jan 3, 2008 | 02:33 PM
MIKE-C5's Avatar
MIKE-C5
St. Jude Donor '05-'06-'08
I run a 335 on the rear and very little rubbing
Old Jan 3, 2008 | 07:31 PM
SuperSpeed's Avatar
SuperSpeed
St. Jude Donor '08-'10
what tires are you guys running for 305/30/19's They cheapest i found were actually the Nitto Invo's
Old Jan 3, 2008 | 07:38 PM
Sherpaboy's Avatar
Sherpaboy
Lowered 2" no issues
CCW SP16A Wheels 19X10 Front 19X11.5 Rear
Michelin Pilot Sport PS2 Tires 275X30X19 Front 305X30X19 Rear
To What sizes do tires start rubbin?
Old Jan 3, 2008 | 07:55 PM
JimZRyd's Avatar
JimZRyd
St. Jude Donor '12
Maybe someone can enlighten me on my issue with my wheels...I wanted to get a more aggressive stance for my 02 C5 convertible. I liked the way a buddy of mine's Z06 sat and went with C6 Z06 wheels 18x9.5F and 18x10.5R with 265/35/zr18s and 295/35/zr19s. This combo opened up more fender well than I like. I am considering switching to a 18x9.5F and 19x11R with 255/40/zr18s and 295/35/zr19s. These are taller than the ones I have and only slightly taller than stock. I prefer not to lower my car as it already scrapes the driveway coming and going. Any advice would be greatly appreciated!
Old Jan 3, 2008 | 11:14 PM
LRRLVETTE's Avatar
LRRLVETTE
Old Jan 4, 2008 | 02:14 AM
1phatc5's Avatar
1phatc5
5th Gear
Default Rubbing on 20's
In order for my 99 to not rub with 19's and 20's and put in 2002 z06 shocks and springs and it solved the issue. Guess the 99's get saggy after a while. The z06 version is a bit stiffer as well and less travel i assume. I put 20 and 22's on and in order for them to not rub in the rears a stiffer set up was involved, that and unordinarily skinnier tire especially for how wide the wheels are to allow the v shaped tire to fit into the fender area for the custom 3 piece wheel with an offset which is flush with the body of the ride.
