ignition problem
Old Jan 2, 2008 | 11:41 AM
defaziot's Avatar
defaziot
3rd Gear
Default ignition problem
I have a 2003 automatic and recently tried to start it up and found that I couldn't turn the key after inserting it into the switch, the trans is in the park position and the steering wheel is not locked, couldn't find anything in the manual, wondering if anyone else has experienced this?
Frustrated
Old Jan 2, 2008 | 12:24 PM
dougbfresh's Avatar
dougbfresh
Do you have a 2nd key to try?
Old Jan 2, 2008 | 12:46 PM
CODE4LS1's Avatar
CODE4LS1
Also try to turn the steering wheel side to side while trying to turn the key to the on position.
Old Jan 2, 2008 | 01:33 PM
Robertelarkin's Avatar
Robertelarkin
Default Same Problem
Frustrated
I had the same problem about 2-3 months ago.
I would insert the key and at first it would not turn, but I jiggled it and worked the stirring wheel, finally the key would turn, but no power. T make a long story short, I was towed to the dealer and it turned out to be a bad ignition cyclinder, I was covered, but the cost was $638.
Do a search for "My car will not start...........HELP"
Old Jan 2, 2008 | 03:23 PM
defaziot's Avatar
defaziot
3rd Gear
Thanks for your help.
Old Jan 3, 2008 | 04:40 PM
defaziot's Avatar
defaziot
3rd Gear
The battery is good, second key did same thing and the steering column isn't locked up. Any other ideas before I have to call for service.
Old Jan 3, 2008 | 04:58 PM
Oh 2 Fun's Avatar
Oh 2 Fun
St. Jude Donor '09, '13, '15
I don't have an automatic, but some cars won't let you start them without the foot on the brake. Is this the case with Corvettes?
And if so, it could be the brake light switch or the fuse for it. I've had that happen on a couple of cars.
Will it let you push the selector into drive? If not, could be what I just described.
I dunno, just a shot.
(edit)...nope, never mind. I just re-read your post and saw that the key won't even turn. Does sound like your ignition switch. Squirt a small amount of WD-40 in there if it won't hurt the key sensor.
To ignition problem
