headlight side hole plugs
Old Jan 4, 2008 | 02:24 PM
Svelte_C5's Avatar
Svelte_C5
St. Jude Donor '09
Default headlight side hole plugs
Ever since I bought the car these have never been there, so I stopped by the dealership and bought a couple for ~$6 each.
I know they rotate and lock into place, but I know it's just a matter of time before they vibrate *cough*runflats*cough* out again so my question is, how can I put them in where they won't come out as easily?
Obviously I could use some industrial strength adhesive but I want them to still be somewhat removable should I ever need to work on the headlight through the hole...
Old Jan 4, 2008 | 02:28 PM
jrprich's Avatar
jrprich
You can remove the entire headlight surround with just three phillips screws.......so many just glue the plugs in place.
Old Jan 4, 2008 | 02:30 PM
Oldvetter's Avatar
Oldvetter
A little silicone sealer goes a long way.
BTW, early C5's used a larger plug which is no longer available. To replace missing plugs on these you must buy new surrounds and plugs.
Old Jan 4, 2008 | 02:39 PM
pimpjames's Avatar
pimpjames
my left one is missing and I didn't realize they were that cheap
bucwheat's Avatar
bucwheat
Got a 98 and they never come out.
Old Jan 4, 2008 | 02:49 PM
PostShawn's Avatar
PostShawn
Just put a dab of adhesive on two spots of the plug and that should hold it. If you ever needed to take them off a quick punch with a flathead screwdriver should pop them right off again if you only do a little drop here and there.
Old Jan 4, 2008 | 03:40 PM
bighank's Avatar
bighank
Default RTV sealer and use the 3 screws
Got an older plug as a sample from Caplugs the mfr. Think it is 2 1/8.
Several posts here including mine telling you about the plugs. BIGHANK
Old Jan 4, 2008 | 04:17 PM
patrickboyle's Avatar
patrickboyle
I had one blow out & over the roof of the car last fall when I opened the headlights for the 2cd time since I owned the car. Could'nt figure out what it was til I got home in the garage. I never drive the car at night here...way to many deer to land in my lap.
Old Jan 4, 2008 | 04:26 PM
The stock plugs on my '99 did the same thing - the dealership replaced the plugs and bezels with a newer ('00 model year) version and they never came loose again. The ones in my '00 have never given me a problem. Might want to either silicone yours into place or just get the newer version of the plugs/bezels.
Old Jan 4, 2008 | 10:25 PM
ROJ#79's Avatar
ROJ#79
If the plugs are missing, just cut a circle out of the tops on black spray cans and super glue them in. If you ever have to adjust the lights just take off the suround with 3 screws. Simple fix and permanet.
Old Jan 4, 2008 | 10:46 PM
6 Shooter's Avatar
6 Shooter
Old Jan 4, 2008 | 10:56 PM
moserbe's Avatar
moserbe
Old Jan 5, 2008 | 12:25 AM
jrose7004's Avatar
jrose7004
My latest C5 didn't have them when I bought it in June so I went to the dealer and got some. They've stayed with no problem.
Old Jan 5, 2008 | 09:21 AM
johnson-rod's Avatar
johnson-rod
Newbie here with a 98 coupe.
I bought a pair of the "old" style plugs from a reputable vendor and found they are just 2 1/8 caplugs that are too small to stay put by themselves. I made backing plates by cutting down spray can tops and ran a screw them both. They remain removable and won't fall out.
To headlight side hole plugs
