Project Number 16,423 Complete.....
Old Jan 5, 2008 | 03:03 AM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
St. Jude Donor '06 & '12
Default Project Number 16,423 Complete.....
I can FINALLY say i'm done!!!!! (Until Monday)
Oh boy does she sound purdy...
Wouldnt you know, I get her running tonight, and its supposed to rain for the next 3 days..
Old Jan 5, 2008 | 03:44 AM
ICULUKN-C5's Avatar
ICULUKN-C5
That is sweet....Love the intake
Old Jan 5, 2008 | 05:20 AM
BurnoutKid's Avatar
BurnoutKid
ok, if you think she sounds purdy let us be the judge
sound clip?
Old Jan 5, 2008 | 08:43 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
WOW
I really can't wait to hear it and see the new numbers for it!
What an awesome intake! I could only imagine how it would like a Turbo on it
Thanks,Matt
Old Jan 5, 2008 | 09:35 AM
4DRUSH's Avatar
4DRUSH
Whats next?
Old Jan 5, 2008 | 09:44 AM
Morzoff's Avatar
Morzoff
Originally Posted by 4DRUSH
Whats next?
Congrat's Jeff
Mike
Old Jan 5, 2008 | 10:16 AM
Mike04's Avatar
Mike04
What's the bet on how long this setup will be in the car
Should be a blast to drive
Old Jan 5, 2008 | 11:04 AM
Yellow03Z06's Avatar
Yellow03Z06
Time for a new NA record
Old Jan 5, 2008 | 11:13 AM
FreddyG's Avatar
FreddyG
Originally Posted by madmatt9471
WOW
Thanks,Matt
From past performances, Jeff will probably be starting that project later in the week!
Just kidding! That is One Very Nice looking setup and if it runs as Nice as it looks, You'll have yourself a BEAST on your hands! Nice Job and Good Luck!!
Old Jan 5, 2008 | 11:55 AM
Apipe's Avatar
Apipe
That has to be one of the most beautiful engines I have ever seen
I love NA combo's
Old Jan 5, 2008 | 12:07 PM
bgreen83's Avatar
bgreen83
Nice setup! Looks Good. Nice work Jeff. Post some more pics and A video is possible.
And what's next? Are you going to join the 4 digit Club with Nick,LB, and eb02z06?
bg
save the wave
Old Jan 5, 2008 | 03:16 PM
Robert56@RNS's Avatar
Robert56@RNS
Collections Hold
Very nice. That intake is to die for. I forget, which hood you running? Should be some serious N/A power.
Robert
Old Jan 5, 2008 | 05:54 PM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
I am running the KB hood..
NA?? Who said NA?? Just cause you cant see the direct port, doesnt mean its not there...
Robert
Old Jan 5, 2008 | 07:08 PM
eb02z06's Avatar
eb02z06
St. Jude Donor '08
Very nice!!!!!
Old Jan 5, 2008 | 08:10 PM
FunCool's Avatar
FunCool
Nice too see someone push to the next level!!!!
Old Jan 5, 2008 | 08:17 PM
Robert56@RNS
Collections Hold
Now we're talking. Have you seen the new A/F interface from HSW. We can dial in A/F ratio much easier now. Get intial A/F close with jets then fine tune through the interface. Interface also has a nice timing pull feature. I have one laying on my desk, but haven't had the chance to get it installed yet. Here's another addition for you, if you don't have one already, the Beer custom sw panel.
Robert
Old Jan 5, 2008 | 09:35 PM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
I got one of the "Beer" specials
But I am VERY interested in that interface you talk about..
Robert
To Project Number 16,423 Complete.....
Old Jan 5, 2008 | 10:13 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
That looks very sexy and looks awesome under your hood
Old Jan 5, 2008 | 10:34 PM
Robert56@RNS
Collections Hold
Here's a basic run down. Link at bottom may have some more insight for ya.
Introducing the world's first Air to Fuel nitrous controller; The HSW Interface. With The Interface controller you can now easily fine tune your air to fuel mixture without the hassle of swapping fuel jets or worrying about the nozzle placement in relation to the MAF sensor on your dry nitrous system. In addition to full control of your A/F curve The Interface can also retard timing when your nitrous system is active, so you can now run full timing NA and make max horsepower & torque and then safely and easily pull timing when your nitrous system is activated. Unlike some other timing controllers The Interface will show the timing being pulled when using a scan tool, so no more worrying if the timing is actually being pulled. The Interface can be easily installed into a pre-existing nitrous system and includes a pre-made wire harness for a simplified installation
Examples of Using The Interface:
Running a Dry Direct Port
Running a Dry Nozzle after the MAF Sensor (or before the MAF Sensor in a poor location)
Running a Dry Plate Kit
Adding fuel to a Wet Direct Port Kit (instead of wasting time changing fuel jets around)
Adding a little extra fuel to a Wet Kit to cure any "Lean Spikes" upon kit activation
How Does The Interface Work?
The Interface makes Air to Fuel adjustments using your Mass Air Flow (MAF) Sensor. Simply program The Interface as to what size shot you are running (adjustable from 5 HP to 315 HP in 5 HP increments). Full control over the A/F curve is now possible, allowing fuel to be added or subtracted. Timing control is done with the vehicles IAT Sensor. The Interface has a built in Diagnostics Mode & Safety Features. If the Interface detects anything wrong with the MAF Sensor it will not allow the nitrous system to become operational and trigger a Service Engine Soon (SES) light until the issue is resolved.
Feature Set of The Interface:
Air to Fuel Control
Timing Retard
Top End Engine RPM A/F Correction (Addition & Subtraction)
12 Volt or Ground Trigger (for easy integration into a pre-existing N2O system)
Adjustable Delay feature to prevent an initial "Overly Rich" condition (Rich Spike)
Built in Safety Features & Diagnostic Mode
Do you have a pic of your Beer sw panel? If so, can I use it in my new web site?
Robert
Last edited by 1%r; Jan 6, 2008 at 03:36 PM. Reason: deleted link to non supporting vendor
Old Jan 6, 2008 | 01:38 AM
RED99's Avatar
RED99
You're complaining about 3 days of rain! You should live where I do.
The motor looks really good. Can't wait to see what the intake and headers does to it.
