Circuit board or electronics gurus needed within
9744 is the device number, and I don't know what the other numbers and letters represent. I doubt that it is a transistor, but a SCR. You can try Newark Electronics, You won't find this at Radio Shack.
Sorry couldn't do more. As the other member said, there probably was an external cause to the failed part.
Might just be able to reflow the solder on each of the pins and surounding components and assure yourself the rivit is holding on tightly and see if it comes back to life.
Stupid me
So now one headlight will go up and down and the other because this is friend will not. I thought it would be simple to find this part take out the old one and solder in the new one. Finding this thing is the most challenging part so far.
I did surface mount technology (the repairing of circuit boards by replacing these types of parts) for Motorola for years and now its to the point where we hardly replace components any more. That's a board swap waiting to happen if I didn't have a schematic of the board where I could test other points of its operation.
Zeke
Bill
I could not find 8219 on the National website however I did locate a device which appears to be similar made by Philips and oddly enough Googling National Semiconductor 8219 returns hits to the Philips part number. The part number is BUK455-100A/B. It has the same pin configuration ie: the Gate, Drain and Source are in the same location and the case style (TO-220) is the same.
I suspect pretty much any TO-220 case (TO-220 is the EIA packaging designator) Power Field Effect Transistor which can handle 25 amps or more, with less then 1 ohm "ON RESISTANCE" having the same pin locations will work. That is my suspicion and your mileage may vary. Ideally you want a device that can handle around 100 volts also. I realize that the car is a 12 volts system but a thing called inductive kickback generated by the motor can produce voltages much higher than the standard 12 volts.
Check Mouser Electronics or Digikey Electronics for supplies. Philips does not talk to individuals. Kind of like trying to buy parts direct from GM. They have a distribution system which you have to use.
Cut the pins on the old device with small wire cutters. Drill out the rivet. Toss the old device. Remove the old pins by heating the pin with the soldering iron and pulling the pin out once it starts to wobble. Just grab it with needle nose pliers. You can use a product called Solderwik to remove the excess solder from the printed circuit pads. Another way I have used in the past is to heat the pad and then rap the board edge down on the benchtop. The solder sloughs and you can pick off any residual. Make sure there are no leftover solder bridges.
If you still have no joy let me know and I will see if I can identify a likely candidate for you to replace the transistor. One last thing to keep in mind is that a lot of part vendors have minimum orders and even if you only need one transistor at a $1.25 you may have to buy a minimum line item number of 25, 50 or greater.
