Rear side markers? (Help!)
Old Jan 6, 2008 | 07:31 PM
CharlieB1979's Avatar
CharlieB1979
Default Rear side markers? (Help!)
Okay, so I want to put on the my new Amber markers, but I have no idea how to remove the current ones. Please help .
Also, if anyone could...I have the rear taillight diamond cut modification too....if anyone would lend the assist, i'd be appreciative.
Old Jan 6, 2008 | 07:39 PM
jraschke11's Avatar
jraschke11
St. Jude Donor '08-'09-'10-'11-'12-'13-'14
Just stick a screwdriver under there and pry them off...
Of course that makes them unusable lol.
I am gluing mine back on. I took mine off and painted them black. Non functional now, possibly illegal, but looks pretty cool.
The marker has two studs that stick through the body and have a plastic nut on the other side that you need to unscrew. You can get to it from underneath the car, might need to remove the rear wheel. I'm sure someone here has more in depth info.
Old Jan 6, 2008 | 08:04 PM
BanditDude's Avatar
BanditDude
http://forums.corvetteforum.com/show...ll+rear+marker
Old Jan 6, 2008 | 08:17 PM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
Take your two outer tail lights out and reach in there to get to them. They each have two nuts holding them in place.
Old Jan 6, 2008 | 08:19 PM
Z28STYLE23's Avatar
Z28STYLE23
Easiest way I would say. Did mine when installing the blackouts.
Old Jan 6, 2008 | 08:27 PM
ALLEGRO's Avatar
ALLEGRO
Fifteen minutes per side and you are done. Really nice improvement if you ask me.
Old Jan 6, 2008 | 08:28 PM
Junkman2008's Avatar
Junkman2008
Before you replace the markers, take the nut that will be holding them on the car and thread the shafts of the new markers. This will make it much easier to get the nut back on the marker once you are installing them in the car.
Old Jan 6, 2008 | 08:29 PM
Bell's Avatar
Bell
Service Manual instructions: remove the outer tail lights.
Old Jan 7, 2008 | 12:15 AM
The front nut is a little tight to get to, but with a box end wrench you can do it. Just be careful and not drop the nut down into the fender area.
Old Jan 7, 2008 | 12:57 AM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '05-'06
if you have a vert you need to loosen your antenna to access the bolts
To Rear side markers? (Help!)
