[Z06] Delrin shift knob-Love it!
Old Jan 7, 2008 | 06:20 PM
meadowz06's Avatar
meadowz06
St. Jude Donor '09 and '13
Default Delrin shift ****-Love it!
Just wanted to give you guys a heads up that I just installed the delrin shift **** on my 02 Z06 and I love it. It is so much easier to shift gears. And the straight **** feels great. Much shorter than the stock ****. If you want a great cheap upgrade, and don't want to change the shifter, I would highly recommend this ****!
Old Jan 7, 2008 | 06:31 PM
ssdeuce's Avatar
ssdeuce
Thanks! I want one when I install my Hurst shifter.
Old Jan 7, 2008 | 06:53 PM
TM-Z06's Avatar
TM-Z06
I liked the Delrin **** alot. Unfortunately, I just sold mine - if it would have fit the C6-Z06 shifter, I would have kept it.
Old Jan 7, 2008 | 07:31 PM
jpandes's Avatar
jpandes
I love my Delrin too. I didn't know that it wasn't going to fit on the C6Z shifter that bought. Damn.
Hey how does you rnew C6Z shifter compare to your OEM C5Z with the Delrin ****? Was it a big improvement?
Old Jan 7, 2008 | 07:43 PM
26myles's Avatar
26myles
Shifting is much smoother and it doesn't burn off your fingers, especially when you're coming up to the line on a hot, sunny day.
Old Jan 7, 2008 | 07:45 PM
TM-Z06's Avatar
TM-Z06
No comparison between the C5 and C6Z shifters. Even with the Delrin ****, the throws on the C5 shifter were quite long. The C6Z shifters has a noticeably shorter throw, and the shifts are much smoother.
Old Jan 7, 2008 | 08:14 PM
jpandes's Avatar
jpandes
Nice! Thanks for the feedback. I am looking forward to getting my ss. I
Old Jan 8, 2008 | 06:58 AM
buckster's Avatar
buckster
I have one also.Waited about 3 months from Ecklers! I am a bit old school,use to have a pistol grip,slap stick in a cuda and also use to a long throw so I love it on my stock shifter.Also like that I can rest my hand on top of it with arm on console quite comfortably.The feel of the grip is super solid and never too hot.I am just a street driver ,no track stuff. The diameter is perfect also.The length perfect as well.
Old Jan 8, 2008 | 11:06 AM
CH.CRAFT's Avatar
CH.CRAFT
HURST W/DELRIN ****
Old Jan 8, 2008 | 09:55 PM
rhneff's Avatar
rhneff
Originally Posted by CH.CRAFT
HURST W/DELRIN ****
+1 for Hurst/delrin ****.
Only issue I've had is the **** gets a bit "slippery" from sweaty hands in Texas in August - really requires a glove for quick/smooth shifting at that point.
Old Jan 9, 2008 | 12:27 AM
Red99FRC's Avatar
Red99FRC
Bob, I've got a solution for your slippery Delrin ****. I had the same issue... There's a product called Plasti-Dip, that is a liquid in a can. It's primarily used for things like coating the handle on a pair of pliers, etc. So, I got a can of black Plasti-Dip, and rigged up a fixture to let me dip the Delrin **** into the Plasti-Dip, without getting it into the threads. I dipped it twice (2 coats). It dries to a smooth, matte finish that has lots of grip. It completely solved my slippery issue with the ****. I think I've still got most of the can left, if it hasn't set up in the can. Since we're both in the same little town, if you want to bring your Delrin **** over some time, we can dip it, and you'll be set. Or, you can get it at Lowe's or Home Depot. Last I checked, Lowe's had black only, and Home Depot had black and red, I think. PM or email me if you're interested...
Al
Old Jan 9, 2008 | 12:41 AM
BitViper's Avatar
BitViper
I love mine too
Old Jan 9, 2008 | 01:30 AM
smellya's Avatar
smellya
I really don't like mine and mine makes alot of noise when you get over 70ish. Its the LG one that is long. May switch back to the stocker. I have the bpp shift also. Very notchy..
Old Jan 9, 2008 | 02:29 AM
rustyguns's Avatar
rustyguns
i must be a freak! i like the stock shifter and ****
Old Jan 9, 2008 | 09:18 AM
CH.CRAFT's Avatar
CH.CRAFT
DIFFERENT STROKES.........FOR DIFFERENT FOLKS............
To Delrin shift knob-Love it!
