Need Help Code Questions
Old Jan 7, 2008 | 11:45 PM
$BROKE$'s Avatar
$BROKE$
Default Need Help Code Questions
I have a 99 frc and I was racing from a dig the other day and as I was about to shift out of 2nd in to 3rd gear at high rpms my car sputtered and started flashing reduced engine power and service traction system.
My question is has this happend to any of yall before and could you help with these codes that came up when I did a scan on the car.
p0102,p0443,p0449,p0704,p0801,p0803,p113 3,p1153,p1514,c1281,c1278
Now I dont know if some of these are old codes or not. I did this check from the cockpit.
Thanks Adam
Old Jan 7, 2008 | 11:48 PM
Tact's Avatar
Tact
Former Law Dawg Moderator
CF St. Jude Co-Organizer
St. Jude Donor '05 thru '24
Thanks Adam
You need to visit this site and go to the tech section.
http://www.corvettedoctor.com/index.html
BTW I hope you were at the track.
Old Jan 7, 2008 | 11:54 PM
4GTABODT's Avatar
4GTABODT
From: Mississauga, Ontario Corvettes were built to be driven...not trailered
St Jude Donor '07-'08-'09
Adam, here's a website that gives you meanings of each code...
What you're talking about sounds very similar to what happened to me last summer...bottom line for me was water got into my Body Control Module (BCM) which is located underneath your passenger floor mat (there's a compartment under there)....and the reason water got in was because my drain plug was clogged.
Take a look at that compartment and see if water got in...if it did, i can connect you with a thread Bill Curlee did on unclogging the plug
Old Jan 8, 2008 | 12:04 AM
$BROKE$'s Avatar
$BROKE$
Thanks guys I appreciate it. The web site helped alot.
Codes equal
p0102 maf sensor circuit low frequincey
p0443 evaporation emissions vent solenoid
p0704 clutch switch circuit
p0801 reverse circuit
p0803 skip shift circuit solenoid
p1133 h02s insufficiant switching
p1153 same as 1133
p1514 throttle body performance
c1281 vses
c1278 tcs teporarily disabled by pcm
Thanks Again
Adam
Old Jan 8, 2008 | 12:41 AM
VetteBoy1979's Avatar
VetteBoy1979
CI 3-4-8 Veteran
St. Jude Donor '07-'09-'12
Codes equal
p1153 same as 1133
c1281 vses
Thanks Again
Adam
Holy crap!
Man, what the heck did you do?
I've never even heard of most of those, especially 1281 or 1278?!?!
Have you changed the clutch already? I'm assuming so. the 1153 and 1133 should be the front o2 sensors, they may need replacing. The skip shift circuit, if you didn't hook the skip shift eliminator back up correctly, this may be the issue. No idea about the other stuff though.
Id also ask if you have changed something on the air intake? The MAF sensor is located at the base of the carbon air bridge, maybe the intake tube is loose? Have you hooked up the NOS already?
Old Jan 8, 2008 | 01:06 AM
5W0P3's Avatar
5W0P3
Personally... i would reset everyone of those codes and then drive around for a few days and see what comes back.
Also check the grounds. I know someone on here has a link to that page that shows how to clean them and where they are.
Old Jan 8, 2008 | 01:21 AM
Bill Dearborn's Avatar
Bill Dearborn
That list is barely useful as you do not have any of the diagnostic info that goes with each code. How many of these codes are current and how many are history? The H or C after the code number lets you know. Use the DIC to clear the codes and drive the car to see what happens and how many codes are set again. Then post what you find in this thread.
Bill
Old Jan 8, 2008 | 02:21 AM
VetteBoy1979
CI 3-4-8 Veteran
A source of issue with P0443:
When the intake is removed, the only two parts of the EVAP system removed are the solenoid electrical connector (driver's side between the intake and valve cover at center of motor) and the EVAP hose between the solenoid and the hose at the firewall. Check these first, the hose or connector may not be on fully.
Old Jan 8, 2008 | 02:24 AM
VetteBoy1979
CI 3-4-8 Veteran
P0704...possible bad clutch sensor. Common after clutch swaps.
http://forums.corvetteforum.com/sear...archid=7079133
Old Jan 8, 2008 | 02:25 AM
VetteBoy1979
CI 3-4-8 Veteran
YES p0801 code is Reverse inhibit solenoid control---either wires are cut--pigtail unplugged or solenoid doa---
Old Jan 8, 2008 | 02:27 AM
VetteBoy1979
CI 3-4-8 Veteran
If you installed the Ls6 intake this could be what is causing the p1514:
http://forums.corvetteforum.com/show...ighlight=p1514
Old Jan 8, 2008 | 02:29 AM
VetteBoy1979
CI 3-4-8 Veteran
Info on c1281 code:
http://forums.corvetteforum.com/sear...archid=7079155
Old Jan 8, 2008 | 09:26 AM
$BROKE$'s Avatar
$BROKE$
Hey Dave no I have not messed with anything as far as removing the cats. I dont know what happened to cause all this bull sh** but the car still runs fine. That has only happened 2 times since I have had the car. Now for the reverse sensor I have know idea of how that happened I just didnt have reverse lights one evening. I dont even drive the car but 2 days a week. Thanks for all the help. When I get home this weekend I will clear all codes to see what comes back and post the results
Thanks Guys
Adam
To Need Help Code Questions
