vented oil cap
Jan 8, 2008 | 06:01 PM
vented oil cap
i am looking for a vented oil cap for my car i have seen them on c5 with super chargers that is what i am looking for
Jan 8, 2008 | 06:05 PM
There is a guy on here that sells three different types. I bought the blue cotton breather. I think it cost about $50.
Do a search for oil breather.
Jan 8, 2008 | 06:29 PM
You could buy a small breather/filter with a rubber nipple on it and just drill your OEM cap and install it in the hole..........
Jan 8, 2008 | 06:43 PM
Jan 8, 2008 | 06:56 PM
St. Jude Contributor
You mean like this one. Call ECS - (609) 752-0321 they'll get you one.
Jan 8, 2008 | 06:59 PM
Quote:
Originally Posted by
Sponge Vette
But sadly...you got blown and I didn't
Yet that is
CALL Chris @ ECS !
Jan 8, 2008 | 07:23 PM
thanks guys i had drilled cap and installed one just looking for a better looking set up than what i have my car was pushing the dip stick out under high rpm i also found one of my pcv rubber elbows was crimped that could have been the problem just wanted the eng. to breath more
Jan 8, 2008 | 07:27 PM
Keep in mind that installing a breather will cause the AFR to lean out if your using the Maf.
Russ Kemp
Jan 8, 2008 | 07:39 PM
my car needs a new tune any way due to installing a fast 90 intake and throttle body
Jan 8, 2008 | 07:47 PM
This is how I hooked up the PCV breather hose to the SLP smooth bellow.
Russ Kemp
