Fast blinker
Old Jan 10, 2008 | 12:31 AM
rkhegler's Avatar
rkhegler
Default Fast blinker
Took the vette out today for a drive. When I used the left turn signal it blinks twice as fast as the right one which blinks normally. Never had this happen before. Anyone else?
Old Jan 10, 2008 | 12:42 AM
The California Kid's Avatar
The California Kid
Usually means one of your bulbs is out
Old Jan 10, 2008 | 12:47 AM
01yellowc5's Avatar
01yellowc5
From: Woodlake,The hill is without the king, California
St. Jude Donor '08
Old Jan 10, 2008 | 01:09 AM
jdmvette's Avatar
jdmvette
Night Owl for life
if the bulb is fine, check the level of your blinker fluid on whichever side is acting funny.
Old Jan 10, 2008 | 01:11 AM
utah997's Avatar
utah997
Team Owner<br><img src="/forums/images/ranks/11k.gif" border="0">
St. Jude Donor '07 thru '13
If not that, then the muffler bearings might be out.
Old Jan 10, 2008 | 01:13 AM
FUN LS1's Avatar
FUN LS1
St. Jude Donor '08-'09
Final check is to make sure your carb isn't too rich or lean.
Or, ask a buddy with a diesel to swap spark plugs with you. That might help.
Old Jan 10, 2008 | 02:49 AM
PUREFUN's Avatar
PUREFUN
St. Jude Donor '07-'08
And the correct answer is from California Kid. The rest are playing with you.
Old Jan 10, 2008 | 03:11 AM
Garrett W's Avatar
Garrett W
nubbbb
Old Jan 10, 2008 | 03:19 AM
Just find the offending bulb, replace it and all things should return to normal.
Old Jan 10, 2008 | 07:02 AM
Bob CTS's Avatar
Bob CTS
+1
Old Jan 10, 2008 | 07:25 AM
Junkman2008's Avatar
Junkman2008
Originally Posted by rspreng02_Z06
+1
+2
I use to deal with this on a monthly basis until I replaced my front lenses which were allowing water to get into the bulb socket, blowing the bulb.
Old Jan 10, 2008 | 07:38 AM
lil vette's Avatar
lil vette
Can also be bad bulb housing....leaking water
Old Jan 10, 2008 | 07:51 AM
rkhegler's Avatar
rkhegler
Thanks for the info. I will check the bulb.
Old Jan 10, 2008 | 11:06 AM
04cad's Avatar
04cad
What type of blinker fluid do you use? I use the one with the lightening bug additive, lasts forever, I neve have to change it
Old Jan 10, 2008 | 11:17 AM
jovette's Avatar
jovette
Yes, but you must remember to change this out for the winterized fluid, don't want it to freeze up on you, and be stuck with no lights!
Old Jan 10, 2008 | 11:47 AM
Vega$Vette's Avatar
Vega$Vette
I never use my turn signals.
Old Jan 10, 2008 | 01:11 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Me either - that's why I have a horn.
To Fast blinker
Old Jan 10, 2008 | 04:09 PM
Junkman2008
That's that Panama City, Mexico mentality! I have the bigger vehicle and I blew my horn thus, I have the right of way!
Old Jan 10, 2008 | 04:29 PM
SavPrato's Avatar
SavPrato
Does this not also happen when you only apply lite pressure to the turn signal? If I lightly touch my signal indicator when I'm changing lanes, it goes off at high speed, as I increase the pressure on the indicator, it returns to normal flashing speed.
Old Jan 10, 2008 | 04:36 PM
PUREFUN's Avatar
PUREFUN
That's because it never gets out of your garage John.
