Can someone tell me how difficult it would be to replace my standard shifter **** off of my 02 Z06 with one of the round shifter *****? Does it just screw on is is it more involved than that?
The hardest part is removing the stock ****. You pry off the shift pattern cover and then you see the "demon key". This has to be pulled/pryed out. Some people use needle nose visegrips. Then you can just screw it off. Good Luck !
New ***** usually just screw on and use a "jam nut" to locate them.
I guess it was like on my 92. I remember that process.
From: Not QUITE the armpit of Southern Maryland, but scary close...
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '04-'05-'06
I had a heck of a time with my demon key. The tabs broke on it as I tried to pull it out with vice-grips. I ended up drilling a hole through the middle of it and running a screw down til it bottomed out on the top of the shift lever. From there, I just kept turning the screw and the key followed the threads up and out.
Here's how I got the key out of my stock shifter - clamp on a good size pair of regular vice grips then take a hammer and gently tap up on the side of the vicegrips. The key popped right out.
A flat blade screw driver under both sides of the Demon Key and evenly push them both down at the same time worked very well for me. I also used some WD40. Came out pretty easy. Don
