[Z06] Fix for vibrating shifter during higher rpms??????????
Old Nov 28, 2001 | 08:55 PM
autolover's Avatar
autolover
Default Fix for vibrating shifter during higher rpms??????????
I think I saw this topic before, but I did not have a ZO6 when I saw it, so I did not pay any attention to it. It is a buzzing vibrating sound that occurs during hard acceleration. How can I stop it, besides slowing down,which is impossible in this car!!!!
Old Nov 28, 2001 | 11:44 PM
Zapper's Avatar
Zapper
Default Re: Fix for vibrating shifter during higher rpms?????????? (autolover)
Is this an aftermarket shifter ?
Old Nov 28, 2001 | 11:48 PM
autolover's Avatar
autolover
Default Re: Fix for vibrating shifter during higher rpms?????????? (Zapper)
No, it is a stock shifter.
Old Nov 29, 2001 | 12:23 AM
Zapper's Avatar
Zapper
OK, so where is the sound coming from ?
Old Nov 29, 2001 | 12:58 AM
autolover's Avatar
autolover
It seems to be coming from the ****. It is a minor issue, but annoying just the same.
Old Nov 29, 2001 | 02:15 AM
Zapper's Avatar
Zapper
The **** is loose. You will have to remove the cover with the shift pattern by prying it up with a small screwdriver, pry out the pin, screw the **** down farther clockwise, then put (hammer) a new pin in and the noise should go away. Let the dealer do it - sounds like a warranty issue to me.
[Modified by Zapper, 12:16 AM 11/29/2001]
Old Nov 29, 2001 | 10:27 AM
levrac68's Avatar
levrac68
I agree with Zapper. After replacing my stock **** and prying that damn T-pin out, I'd say that going to the dealer is your best bet. You know, this may be the only case that I'd suggest a dealer. :lol:
Old Nov 29, 2001 | 11:49 AM
jerryv's Avatar
jerryv
Default Re: Fix for vibrating shifter during higher rpms?????????? (levrac68)
It's the top of the shift boot rubbing against the shaft of the shifter. Try running up the revs until you get the noise, then push around with your finger at the top of the boot and see if you can make the noise stop. This is a very common complaint on Z06s. I think a leather-friendly lubricant between the top of the boot and the shaft will eliminate the noise.
Old Nov 29, 2001 | 11:33 PM
DLSCWBYVT's Avatar
DLSCWBYVT
I have an aftermarket shifter. I used 3/8 inch heater hose on mine to cut down on the vibration. Still does a bit at high rpms...thats the price you pay to have a shorter throw. :eek:
To Fix for vibrating shifter during higher rpms??????????
