Options
Old Jan 11, 2008 | 10:01 PM
FussBudget's Avatar
FussBudget
Default Options
Can someone possibly tell me what options I have and their definitions? Thanks!
VIN: 1G1YY22G045100148
Old Jan 11, 2008 | 10:21 PM
99mallett's Avatar
99mallett
From: The line waiting to see Santa Claus stretched all the way back to Terre Haute, and I was at the end, Indiana
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18
Can't tell that much from the VIN. Check the glovebox for the RPO numbers. Go to the local book store and get a Corvette Black Book (about $15). This should tell you most anything you want about how your car is equipped.
Old Jan 11, 2008 | 11:54 PM
WetteVette's Avatar
WetteVette
And if you can't find the options tag in your car, you could always order a copy of the original window sticker from the National Corvette Museum.
Old Jan 12, 2008 | 12:05 AM
GrayC5's Avatar
GrayC5
As mentioned above, check the Service Parts Identification (RPO) Label on the inside of your glove box lid. The following link will help you decipher the RPO Codes:
Chevrolet Corvette C5 RPO Code List
Service Parts Identification Label:
Old Jan 12, 2008 | 12:09 AM
Cozmo's Avatar
Cozmo
CentralTX Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
There are several CF members who can run your vin, provide all of your option codes and vehicle repair history. Forum member ja03c5 did that for me. If no one else responds, try sending him a pm.
Old Jan 12, 2008 | 08:55 AM
FussBudget's Avatar
FussBudget
Thank you all for the helpful info.
Old Jan 12, 2008 | 09:19 AM
cookrent's Avatar
cookrent
St. Jude Donor '08
I went to local dealer and he printed one for me.
Old Jan 12, 2008 | 09:22 AM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
As was noted you can check the decal in the glove box and compare it to the RPO code list provided. You can also send a PM to forum member GMautotech and he can run your VIN through the GM VIS. He does this routinely. You can reach him here:
http://forums.corvetteforum.com/member.php?u=221526
Old Jan 12, 2008 | 10:49 AM
FussBudget's Avatar
FussBudget
Done.
To Options
