Pros & Cons Lowering 2004 Vert?
Jan 11, 2008 | 10:37 PM
What Are The Pros/cons Of Lowering 2004 Vert?ride Stiffness?tires Rubbing?
Jan 11, 2008 | 10:39 PM
looks better but you will scrape more
Jan 11, 2008 | 10:43 PM
All Men Die, but Few LIVE
Cruise-In IX Veteran
St. Jude Donor '08-'09
Looks Good...but you will scrape MUCH, MUCH more often, you'll still scrape, no matter how slow you go...but it WILL look good! I wound up lowering mine,..then raised it back to half way between the two....sort of a compromise, still scrape some though.
~Maverick
Jan 11, 2008 | 10:54 PM
St. Jude Donor '08
I lowered my 00 Coupe on stock bolts and have had no real problems with scraping or tires rubbing (uprgaded to Z06 tires & rims)...
get the rocker savers just in case... and it looks great !!
Jan 11, 2008 | 10:55 PM
lowering
thanx guys just what i thought are there different heights or settings?
Jan 11, 2008 | 10:56 PM
Looks so much better...so it's worth a little rub on the front valiance from time to time...no big deal.
Jan 11, 2008 | 10:58 PM
lowering
how much for rocker savers?
Jan 11, 2008 | 11:03 PM
Quote:
Originally Posted by
epti88
I think I paid around $60? ...Oh ..and it's all about the look! ...
Jan 12, 2008 | 11:09 AM
NICE LOOK MAY R WILL GIVE UP A LITTLE IN TRAVEL IN THE SHOCKS. GET THE SAVERS, THEY COME IN DIFF COLORS ALSO. HAVE A SET OF NEW COILOVERS IF YOU WANT TO DO IT THE BEST WAY.
Jan 12, 2008 | 12:27 PM
St. Jude Donor '08
epti88
approx $ 60... contact Nasty98...he set me up with a set...
Jan 12, 2008 | 12:42 PM
You'll probably get more replies if you ask a moderator to move this to C5 Tech instead.
This is the classified ads forum.
Jan 12, 2008 | 12:49 PM
What exactly are these rocker savers ya'll speak of? Got a picture?
J
Jan 12, 2008 | 02:54 PM
St. Jude Donor '06-'07-'08-'09
Pros: Looks much better
Cons: can't think of any unless you lower it too far
Lowered a little over 1 1/2"
