battery charger question
Old Jan 11, 2008 | 11:24 PM
cosvette's Avatar
cosvette
Default battery charger question
I have a 6/2 amp battery charger I use for deep cycle marine batteries that I might need to use on my snowbound '99 Coupe. It will trickle charge at 2 amps, but I see many recommendations on this forum for Battery Tenders that charge at only 1.25 amps.
Is the 1.25 amp output essential if the charger will be connected for extended periods or will my 2 amp charger work just as well? Does the battery have to be removed from the car or can I leave it connected and charge/maintain for say 18-24 hours without any damage to battery or systems?
I've never had a problem leaving my boat batteries charging at 2 amps for extended periods but they weren't installed in an expensive (to me) vehicle with complicated systems, so I thought I'd better ask.
Old Jan 11, 2008 | 11:41 PM
10U 99's Avatar
10U 99
St. Jude Donor '08-'09
I would be hesitant leaving a charger connected for an extended period that wasn't designed to do so. battery tenders/maintainers are pretty inexpensive so would it be worth the risk?
Old Jan 11, 2008 | 11:45 PM
Slotcar's Avatar
Slotcar
It is not so much the amp charge as much as the fact that they stop when fully charged. A good tender monitors the battery and charges when needed and stops when it reaches peak charge. Continueing to charge could damage your battery or cause it to leak. A good quality tender is very inexpensive compared to the potential damage.
Old Jan 11, 2008 | 11:48 PM
ljthe2nd's Avatar
ljthe2nd
overcharging (which is what you'll be doing after it reaches a full charge) for an extended period of time will lead to early battery failure
Old Jan 11, 2008 | 11:54 PM
silverbullit99's Avatar
silverbullit99
With the Battery Tender you can leave it plugged in 7/24 with no problem. It's designed with a float that will prevent over charging. I had a regular battery charger but switched to the tender .... problem free
Old Jan 12, 2008 | 12:04 AM
cosvette's Avatar
cosvette
Default thanks
Thanks for the quick replies. Looks like a Battery Tender is the answer.
Can I leave the battery installed in the car while charging/maintaining? It would only be until the snow melts in my cul-de-sac and I can get out on the road again for a good run (few days/week at a time), not all winter.
Old Jan 12, 2008 | 12:11 AM
silverbullit99
Yes ,, leave the battery hooked up,, keeps all the car's electrical stuff ready to go..
To battery charger question
